Question about GE Monogram ZDI15C Automatic Icemaker
Ice maker makes a loud squeaking noise when filling up with water
SOURCE: Ge monogram ice maker makes loud churning noise
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Posted on Jun 17, 2009
SOURCE: GE ice maker, solid ice in ice maker
ice clumps up in the ice bucket
Posted on Jul 24, 2009
  • 153 Answers
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Posted on Feb 28, 2010
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
aasc
  • 1606 Answers
SOURCE: water dispenser does not work
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on May 02, 2010
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Motor Noise?
it may be the compressor turning off and on
May 31, 2013 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Brand new machine. Just hooked it up. When the water reservoir fills the filling action is LOUD. Once full and the freezing cycle starts, it is quiet as a mouse. Freezes, ice falls, reservoir fills -...
It is the nose of the water moving through the fill valve . If your pressure is very high try closing the valve supplying the water a bit may help but some noise is normal . If it is very annoying call a tech and have it checked out.
Dec 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
My freezer compartment is making a loud vibrating noise. The ice maker is not working, the water freezes on the inlet ramp to the cube maker. What gives?
The vibration is usually an unballance, check the freezer fan blade for any broken pieces. The water freeze will cause the Ice maker to not work..if the fill valve for the ice maker leaks, even a small bit it will freeze up on that "inlet ramp" if so, replace the fill valve. Else, I've found a unit not used, left alone for a week or more.. that tube still freezes up...gets too cold?
Oct 24, 2009 | Frigidaire Refrigerators
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
Ice maker noise when filling
replace the water fill valve it is at the bottom where the water line conect to the unit
Nov 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZDI15C Automatic Icemaker Logo
97 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
