Question about Sony STR-DE595 5-Channel Amplifier
The sound on my sony amplifier sounds too low inside the speaker.
When you hear the music it sounds like it is inside the speaker and not
amplified like it should be. I need to press the right buttons in order to
make it soud right.
Thank You
I.Garcia
  • Scott Frye
    Scott Frye May 11, 2010
    Do you have the owners manual?
I had a similar problem with my STR-DB930 and I think it was solved by turning the speaker select knob on the front left hand side of the amp to "A" rather than "A+B". As I only have front speakers connected to the A terminals, not both A and B.
Posted on Jul 04, 2009
  • 85 Answers
Try getting the suround sound modes off and using straight stereo ,with no delays,or echos,
Posted on Jan 15, 2009
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
With my amplifier sony TA V902 I don't have sound out from any source.
when you amplifier is powered on if the speakers are powered on and you hear that the output is switch on then it is possible that the fault of the amplifier is in the preamplifier.Open the set and check on the input of the amplifier with a signal . If there is output the fact is confirmed of the preamp stage. Now we have to confirm if the fault is in the source swtiching or the preamp equaliser/ tone section. Using a good signal tester and hoping that you are familiar to handle the electronics inside, the IC can be identified and changed. Use extreme care and test at low output, Use a help of an expert to signal trace the fault. Hope I could help. Good day
May 28, 2010 | Sony Audio Players & Recorders
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
Hi I have got a sony TAFE 370 amplifier which does not produce any output, i have tried different input devices and also checked speaker wiring and the speaker selection is on i used it a day ago and all...
If you can't hear any sound from the headphone output, and by sound I mean a hum with the volume turned up, then the amp has either got a faulty internal power supply or the main amp has failed. Try looking inside to see if any fuse has blown. Also look around to see if you can see or smell anything has blown.
Sep 24, 2009 | Sony TA-FE370 2-Channel Amplifier
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
People can hear me speak but I can't hear them
Sound inducers do go bad. Normal the same audio amplifier is used for both the ear piece and the speaker. Since the speak does work, it sounds like the ear piece has died.
May 28, 2009 | Lands Phones
The volume is too low on my computer speakers
Hi, Mark Here, see I can help.
The 1907 does not amplify your sound it will let you control the volume to some degree but not boost the incoming sound.
If you had amplified speakers b4 your sound card requires amplified speakers.
Best two options i can give is.
  1. If it is a desktop you can install a amplified sound card. Hook to monitor speaker.
  2. Unplug monitor speaker &use amplified speakers.
Just so you know laptops use internal amplified speakers. If you decide to install sound card make sure it is an amplified card.
Hope that fixed ya! know not the best news. Need more help comment back. Please Rate.
Good Luck!
Mar 28, 2009 | HP w1907 LCD Monitor
No sound
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sound problem in 97 dodge stratus
I had the same problem.. and I fixed it. The problem is the stock amplifier under the passenger seat.. What happens is you are pushing more amps from the cd player through the amplifier than the amplifier put out in the first place, so the amp acts as a resistor, and for some reason it causes the speakers to cut out when turning signal, brake lights, wipers, or any lights/electrical are applied. The only solution I know is to wire straight from your cd player to the speaker itself.. it's kind of a job but if you like wiring etc. it turns out alright.
Hope this helps,
Kyle
Sep 07, 2008 | 1997 Dodge Stratus
Amplifier
check faulty or old connections esp rca
Apr 06, 2007 | Power Acoustik LT-980/2 Car Audio...
Sony STR-DE595 5-Channel Amplifier Logo
349 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
