Question about Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump
Craftsman air compressor model 919-167342 recall
Motor overheating recall
  • 89 Answers
SOURCE: craftsman air compressor 15gals 1.5hp holds at 80psi
REGULATOR NEEDS TO BE TURNED UP. SOUNDS LIKE THE LOW PRESSURE SIDE IS WORKING. MAYBE THE HIGH PRESSURE VALVES ARE NOT WORKING CORRECTLY IN THE HEAD. MARK THE CORNER OF THE HEAD AND VALVE PLATE AND REMOVE - MAKE SURE THEY ARE NOT BROKEN AND THEY ARE OPENING & CLOSING ALL THE WAY. MARK "UP" ON PLATE SO YOU DONT FLIP IT ACCIDENTLY. HIGH PRESSURE PISTON ROD IS BROKEN AND NOT GOING UP AND DOWN.
Posted on Mar 14, 2009
  • 1383 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
Skinnerd1
  • 13 Answers
SOURCE: craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
Posted on May 22, 2009
  • 98 Answers
SOURCE: where do i find the Owners Manual or Service
Its best to use a 30wt non detergant
Posted on Jul 21, 2009
  • 41 Answers
SOURCE: Compressor turns on but no air in tank. Oil level
Dismentl the valve plate check the gaskets and the valves,cif not good change and it wlii be ok
Posted on Oct 10, 2009
Craftsman model #921166390 motor
The motor does not take oil on that unit. The compressor housing does though. If you cant get it to start after it ran dry, the cylinder is most likely seized to the piston.
Mar 03, 2014 | Craftsman Air Tools & Compressors
How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
Aug 02, 2010 | Craftsman Air Tools & Compressors
Setting the max pressure on a Craftsman compressor
The pressure setting for on off of the compressor , and the operating pressure don't have to be the same. You should have two gauges. One for tank pressure, and one for operating pressure. Turn the large knob on the operating pressure, ccw to decrease and cw (clockwise) to increase. You can download a manual for your compressor at:
http://powertool.manualsonline.com/ex/thread/view/idThread/839583
Jul 18, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Craftsman 1 hp, 3 gal air compressor model #921.153101 that wont pump air, the motor runs fine, the hose is clear what can I do to get it running?
Remove the air filter and see if the inlet is sucking air if so the unit is pumping,if not the valves could be bad or the piston is broken.
Apr 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Dec 24, 2009 | Air Tools & Compressors
Broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Nov 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do i remove the air pump assembly off my craftsman 6HP air compressor, Model Number #919.152930. seems like its bolted directly to motor.
It is in fact bolted directly to the motor. You should be able to do any repairs necessary without removing the pump from the motor. I am not sure of the set up of that motor. I'm not sure if undoing that plate will also remove that side of the motor. (Something you probably don't want to do.) If you see other screws or bolts under the plate I would assume that you are safe to remove the pump plate from the motor.
Sep 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman air compressor bearing flywheel
Hope this helps.
May 21, 2009 | Craftsman Air Tools & Compressors
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pump Logo
81 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
