Question about Garden
Mower will not run - Garden
    New Friend:
    Problem Solver:
  • 6 Answers
First pull the rope and see if it has compression. rope should not be too easy you will fill when the piston goes throughh its power stroke it will get harder. If so see if it has spark compression and spark . 9 x out of ten for me anyhow is i have no spark. so take the top end off. mounted on the head off mower will be a coil and the coil rest against the flywheel. the flywheel will have some magnetic strips on it ok sand them down lightly with steal wool and do the same for the coil then for me i don't actually know the correct feeler gauge measurement to maintain distance between the too pieces but i just use a match book top to set between them it always works annd then check for spark if you steal have no spark see if when you pull back the cable on the handleconected down by the flywheel moves it all the way back if it does not it will just ground itself out. i had that problem mine would move but not all the way so it was resting against the flywheel ever so slightly and if it steal no spark the coil you have must be no good.. try and see if you have some friends that might have an old junk one around similar to yours if so try those to buy them new Is ridiculously over price to me . For example my weed eaters coil went bad was going to buy a new one but they wanted over 65 dollars and i only spent 110.00 on it bran new so might as well buy a new one
Posted on Dec 07, 2012
  • Dale Howe Dec 08, 2012
    Thank you for info, Valves needed to be adjusted, Run fine now.
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Aug 01, 2015 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower starts thenquits running
Try starting the mower with gas cap removed (be careful as there may be some gas spillage or splash), if the mower runs OK it means the vent holes in cap are plugged, cap should be replaced. If mowere does not run OK probable cause may be dirt or contaminates in carberator and needs rebuilt or cleaned.
Oct 03, 2014 | Garden
LAWN MOWER ONLY RUNS ON CHOKE
RUN ONLY WITH CHOKE, IS FUEL PROBLEM. CHECK FUEL CAP TO REMOVE FUEL LINE FROM CARB. NEED FUEL RUN OUT LINE.
May 14, 2012 | Garden
Mover is running too fast
Either the mower is running a bit lean or the speed governor is broken or damaged. Both of these conditions are bad for you and the mower. You should probably take your mower to a local shop for service.
If you want to rule out the lean conditon you can remove the mowers carb bowl underneath the carb and run a bit of fine wire through the main jets. The jets are usually in the bolt that holds on the carb. There is a very tiny jet near the top of the threads that you should find after a light wire brushing. It is really small! Use a magnafying glass if you can find it.
Be sure to check for leaks when you put the bowl back on the carb.
Dont run the mower if there are any fuel leaks!
Good luck and be careful.
Jul 24, 2010 | Mtd Garden
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
