Question about Whirlpool ATW4475VQ Washer
My admiral washing machine fills with water then just hums
Just hums
  • 15 Answers
SOURCE: GE washing machine Mod.# WVSR1060DOWW
I love spiderpig
Posted on Jul 13, 2008
honeymokey
  • 3113 Answers
SOURCE: my wash machine filled up with water then won't do anything else
fix the lid switch!
Posted on Apr 08, 2009
canbruce75
  • 1776 Answers
SOURCE: wasing machine filled with water overnight
This is caused by a faulty solenoid at the water inlet valve. The solenoids can be tested for continuity using a multimeter. A lack of continuity indicates a faulty solenoid. I am attaching a photo for reference. Hope this helps and best wishes.
Posted on Aug 07, 2009
lavon82931
  • 17 Answers
SOURCE: Washer hums
Under the tub is a round coupling that wears out. This needs to be replaced. When the washer is over loaded it puts to much stress on this coupling and wears it out. You have to take out the drum to replace it. As for it not filling, check the water vavles that supply the washer they may have been turned off
Posted on Sep 14, 2009
  • 82 Answers
SOURCE: washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Posted on Jan 16, 2010
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
Water won't come in. Hums, fill light flashes once but no water
Sounds like a bad inlet valve--the part the hoses connect to. You may want to check that the house valve at the washer did not somehow get turned off also. The hum is the valve trying to open.
May 20, 2015 | Admiral Washing Machines
Admiral washer
good day,
if the main switch is always trip off you have big problem in your machine and not to advise do by your self if you dont have any idea where, or what you need to check?
call the technician for your safety and not to waste money.
Nov 02, 2013 | Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Jul 03, 2012 | Admiral Washing Machines
Water does not fill into
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 19, 2011 | Admiral AW22 Top Load Washer
Washer will not fill with cold water only hot
heatman101
Apr 19, 2011 | Admiral Washing Machines
When i try and start the washer it hums it won't fill it spins just won't fill
Hi and welcome to FixYa, I am Kelly
Turn off the water at the wall connection remove the hoses noting the positons of HOT and COLD. Then clean the inlet screens in the water valve. (lift out by using a knife blade on the outside of the screen) Wash the screens by rubbing your fingers ofer them under slow running water then reinstall them.
Before you start try a hot wash.. and then cold wash to see if either has water coming into the machine. If it works there is a way to back flush the water valve using a warm water wash. You remove one hose and stick it in a bucket. Turn ON the other hose and let water flow into the bucket while gentily tapping on the hose connection with a screw driver HANDLE. Reverse hose connections and repeat hose in bucket and tapping on hose connection. Reconnect both hoses then try HOT and COLD wash fill cycles. Let me know what happened.
Thanks for choosing FixYa,
Kelly
Dec 13, 2010 | Admiral Washing Machines
My Admiral AAV7000A will fill with water but wont spin or drain, whenever i pull the knob out it just hums.
Could be the timer or the motor. I'd check the timer first. Hope this helps! Ella
Aug 17, 2009 | Admiral AAV7000A
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Whirlpool ATW4475VQ Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
