Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Machine is displaying the error message F-04 - Hotpoint Ultima WD72 Front Load Washer/Dryer
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
F04 - Pressure switch jammed on empty
Posted on Dec 05, 2012
  • Tracy Noble Dec 05, 2012
    Thank you Richard - how do I resolve this?
Error 0 problem
see the error +causes +remedy:God bless you
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
to external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.2_4_2013_5_52_44_pm.gif
Feb 04, 2013 | Proform Sport 1000 Folding Treadmill...
Pro-Plus error Panel 03
Description
Possible Causes
Possible Remedies
Remember PCA, mean Printed circuit assembly with the componentsattached.
God bless you
Jan 14, 2013 | Exercise & Fitness
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
My v fit treadmill is not working. It is displaying E1. Is this a trouble shooting code?
Dear Sir:
Hello, I am glad that you contact us.
I will give some Tips:
1) Your Error C is for Troubleshooting, only that message, is must be special some times.
2) Your Error C, has some interpretation depend of the factory.
3) Example: E 01: Mean Replace VSD( Variable Speed Drive) to due some Microprocessor Chip Failure: The Option will be replace Board VSD, but you must contact to the Company for to Fix the Board.
4) The another Alternative: If your equipment has Servo Motor:the enconder is Malfunction: You must Re-Start Machine, and follow again. If the problem persist, You must exchange: a) Servo Motor b) or The Drive Board.or Both.
5) The following alternative is:
Description
Possible Causes
Possible Remedies
I hope that you can resolve this, and take your final step.
Thank you in advance, sincerely. God bless you.
I you Need additional help, you can reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Exercise & Fitness
9.1.0 TREADMILL PRECOR PACE ERROR 3
Dear Sir:
Hello I hope everything is fine.
Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 25, 2011 | Precor 9.21 Treadmill
I just bough a digital cannon T1I and every time I shoot the camera give me an error message
What error message is displayed? If Error 99, This article will lead you through the steps to identify the cause and a possible fix for this error.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
If not, then I suggest you do a web search for the specific error number displayed and see what problem is indicated by the error. That may lead you to a solution.
Oct 04, 2010 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Error message reads: Pace error #1
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
May 23, 2010 | Precor 9.21 Treadmill
Precor m 9.5 error code 4
Precor Error 04, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 04
Mar 02, 2010 | Exercise & Fitness
Problem with printer error # 1203
Unplug your device and replug it after sometime. Now run Reginout scan and reset your machine. Hope it would help you. Thanks
Dec 13, 2009 | Lexmark X2500 All-In-One Printer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
