Question about Sansui Audio Players & Recorders
I have a sansui 5500 receiver everything works except the fm radio, nothing at all, whats wrong, please help
    Sergeant:
  • 256 Answers
Do you have a FM antena hook up to it?
Posted on Dec 06, 2012
  • 298 Answers
SOURCE: My Klh r3000 receiver is
If the antenna is in a basement that is the problem - the fact that it is below ground means that no signals can get through.
Radio signals are blocked by buildings, large lumps of metal or other solid objects as well as strong magnetic fields (which can include electrical devices within the home).
To pick up good radio reception you will need an external antenna above the ground level - preferably as high as you can get it. Unless you get an omni-directional antenna like this one http://www.maplin.co.uk/vhf-fm-omnidirectional-aerial-874 you will need to point the antenna accurately at the transmitting station (+ or - about 5 degrees) for FM. At a pinch you might get by with an indoor aerial but it needs to be above ground level (inside a roof would be best)
Good external AM Radio aerials are harder to find these days.
Posted on Feb 25, 2011
ginko
  • 19396 Answers
SOURCE: I have an older (10
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Posted on Sep 21, 2008
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
SOURCE: Hi, Experts, Vintage Sansui 5050 receiver.
Check for 19 Kz on stero decoder that requires calibration adjustment.
Instrument you need:
Occiloscope or frequezy counter and adj driver .
Good lock.
Posted on Jul 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: just picked up a Denon AVR-3801 receiver and
copy and paste this link in your address bar to view your manual:
www.manualnguide.com/.../manual.../denon-avr-3801-av-receiver-owners-manual.htm
Posted on Oct 01, 2009
Am-fm doesn't work on radio 2001 tahoe, everything else works, what could be the problem
Antenna connection is the place I'd start with. Something is wrong with the cable or the connector.
Aug 23, 2012 | ACDelco 2001-2006 AC DELCO-FW311 Chevy...
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Sep 21, 2008 | Sansui Audio Players & Recorders
My Klh r3000 receiver is great for everything except picking up am or fm stations? I had an antenna attached, but the unit is in my basement, and I get no signals at all. What could I be doing wrong?
Feb 24, 2011 | KLH R3100 Receiver
Receiving AM & FM stations but NO AUDIO OUTPUT
Please post the make and model number of your radio to help us help you.
The more information you provide, the more specific and accurate our solutions can be.
Apr 15, 2010 | Audio Players & Recorders
Does not receive FM signals anymore, just noise.
The T6310 is a disposable radio. Assuming the programming is correct, and matching on each of your radios, and you are using good batteries, there is nothing which can be done to correct the problem. We would however, suggest you double check your programming, and also the age of your batteries.
Sidenote: Rechargeable batteries only last 18-24 months before they begin to fail. Signs of failure can include, but are not limited to, poor transmit, intermittent transmit, white noise, squelching sounds. It takes more energy to transmit than to receive, so your transmit would be the first to go.
Nov 20, 2008 | Motorola Walkie Talkies 2-Way Radio
Sansui s-x 700 no fm reception only noise
i have a sx700 sansui receiver, that the receiver is working fine.
My problem is on the amplifier section
Do you have a schematic diagram ?
Beeing an old amateur radio technician, that is, working with sophisticated receivers don´t see any problem to help you.
It is my oopinion however that unless I can have a copy of the complete schematic diagram it will be impossibleto start giving you ideas
Can you provide me a coopy of the schematic diagram
And tell me if the amplifier section is working fine and also (very important) if other frequencies, excluding fm are working.
Thank you inadvance,
regards from
paulobelardi@gmail.com
Sep 13, 2008 | Audio Players & Recorders
May 25, 2008 | Audio Players & Recorders
I have a sansui receiver 9900z with a broken antena,I think. The broken part was connected to the rear near the antena connectors. I am not sure if this is suppose to ba a antena or not? The set plays well...
The back of the receiver should be marked for FM and AM antenna connections.
Usually the FM antenna needs at least a dipole antenna or a "T" antenna. The part that broke off is probably just the AM antenna.
If you go to your local Radio Shack, you can get a cheap AM/FM antenna for under 20.00. (probably under 10.00)
After hooking up an antenna, you should be good to go.
I hope this helps.
Good luck.
Please remember to leave a rating if I have helped you with your question.
Mac =)
Mar 30, 2008 | Audio Players & Recorders
No AM long wave radio
The antenna wire could be loose.
Jul 17, 2007 | Kenwood KDC-3021 CD Player
154 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
