Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Installation i have 4 wires red,green, blue, white how do i install?
Where do i connect the red yellow green white wires on a hunter 44860
Posted on Jun 06, 2009
  • 59 Answers
IMPORTANT THEASE ARE TRADE STANDERD
red to r
green to g
white to w
blue to y assuming
  • R: It is the main transformer low voltage wire. It comes off of the transformer and feeds to the thermostat.
  • Y: It is the compressor wire and is connected to the other side of the compressor.
  • G: It is for fan. It is connected to one side of the fan relay and there is a common wire on the other side.
  • W: It is for strip heat. The strip heat has a relay and common side. The wire is connected to the other side.
  • Posted on Jan 22, 2009
    3 Suggested Answers
    • 377 Answers
    SOURCE: Installing fan & light control (27182) - in
    Under normal circumstances, NO! Black is normally power in to a box and to a switch. The switch controls the power out to the red line and most likely the blue line. White is always circuit neutral (ground). Your power will most likely come in via black and then go to the lights on either red or blue and to the fan on the other wire, either red or blue, the color you did NOT use for the lights. Some place you should also have a bare or green wire that would act as equipment ground, connecting to the metal of the box.
    Posted on Sep 06, 2010
    • 557 Answers
    SOURCE: I disconnected my 4 wire Honeywell manual
    look closely on the new stat, it should have a G for green Y for yellow and so on sometimes hard to see the little letters
    Posted on Oct 23, 2010
    I would like to install a Pioneer DEH-P3800MP stereo system in it and don't know which wires connect to the stereo!
    2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
    Jun 22, 2011 | 2000 Hyundai Elantra
    I am trying to install a Panasonic stereo to a mitsubishi mirage 1996, trying to find wire diagram for vehicle, the one I found on net was completely different from wiring colours in vehicle.
    Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Driver's Pillar Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
    May 14, 2011 | Mitsubishi Mirage Cars & Trucks
    Just need a diagram showing how to install the
    If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
    However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
    What/ Color/ Where:
    Constant 12V+ White Ignition Switch Harness
    Starter Black/White Ignition Switch Harness
    Ignition Black/Yellow Ignition Switch Harness
    Accessory Yellow Ignition Switch Harness
    Tach Blue Distributor
    Brake Switch Green/White Brake Switch
    Trunk Pin Green/Black (-) Above Fuse Panel
    Parking Lights Red/Black Above Fuse Panel
    Head Lamp Red/White Steering Column
    Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
    Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
    Door Unlock Green/Red (-) Driver's Running Board
    Horn Wire Blue/Red (-) Steering Column, use Relay
    Windows Up LF=Red/Blue, RF=Blue/Yellow
    Windows Down LF=Red/Yellow, RF=Blue/Green
    Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
    Trying to connect a teekonsha voyager brake control to a 2003 expedition
    Their should be a 6 pin conector that only 4 pins are used somtimes a 5th wire is installed for illumination, don't worrie about using that one. The connector is located in one or two different spots, the most popular place is under the dash on the drivers side just below the steering column the connector is grey. The colors are black or red / blue / green / white and sometimes a small black or brown wire is for illumination, don't worrie about that wire. Their are wiring harnasses for sell to hook the brake control through the conector, but if you do not want to buy an adapter hook the wires as followed: Vehicle Brake Control
    Black or Red Black
    Blue Blue
    Green Red
    White White
    Black is power in to the brake control
    Blue is the trailer brake feed
    Green is brake signal
    White is Ground for the brake control
    May 31, 2009 | 2003 Ford Expedition
    Wiring on a RCA RJ-45 wall jack
    the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
    1 Blue --- Orange/White
    2 Orange --- Orange
    3 Black --- Green/White
    4 Red --- Blue
    5 Green --- Blue/White
    6 Yellow --- Green
    7 Brown --- Brown/White
    8 White --- Brown
    I'd still recommend a CAT5 wallplate with a CAT5 jack.
    Apr 11, 2009 | Computers & Internet
    I need a diagram for installing a radio with out a wirering harness
    Have fun.
    1995 Isuzu Rodeo Stereo Wiring Constant 12V+ Red/White Switched 12V+ Brown/White Ground Black Illumination Green/Red Dimmer n/a Antenna Right Front Front Speakers 4" Dash Left Front (+) Blue/Yellow Left Front (-) Yellow Right Front (+) Green/White Right Front (-) Gray/White Rear Speakers 4" Side Panels Left Rear (+) White Left Rear (-) Red/White Right Rear (+) Orange Right Rear (-) Black/Orange
    Feb 26, 2009 | 1995 Isuzu Rodeo
    Radio installation
    Dec 30, 2008 | 1995 Isuzu Rodeo
    RADIO INSTALLING
    there is a code for color!? ok, wait im searching...
    found it! here you go, hope it helps...
    Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
    Jun 19, 2008 | 2001 Chevrolet Tahoe
    Plymouth voyager
    Hi Marlon,
    Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
    Nov 24, 2007 | Car Audio & Video
    Hunter Fan Company 5/1/1 Programmable Thermostat Logo
    296 people viewed this question
    Top Hunter Dryers Experts
    Paul Bade
    Thomas Perkins
    Thomas Perkins
    Are you a Hunter Dryer Expert? Answer questions, earn points and help others
