Question about Broan-NuTone Kitchen Ranges
The fan sqwitch on my model number LR61411 range hood fan fell apart. I would like to either put it bawck together or replace it.There doesn't appear to have been electrical shorts - it just fell
See above
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
zeusfaber
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Posted on Apr 05, 2008
  • 6 Answers
SOURCE: fan blades or motor in Nucor over the stove hood
The FR Series fans from Fantech are glued closed to prevent air leakage. Its better to replace the fan than to try and fix it. The cheapest place to buy a Fantech fan is at http:///www.hvacquick.com as they buy direct from Fantech.
Alos the FR Series fan comes with a 5 Year Manufactures warranty.
Posted on Feb 10, 2009
SparkyNZ
  • 43 Answers
SOURCE: Trying to figure out how to put back together an
Good luck. I would myself try to find a general stove schematic and work out how different it is. There may be a few different rated thermostats and elements, but the bulk of the wiring pattern will be similar.
It may have to come a bit of trial and error as well.
(also, they disassembled the wiring to clean it? that's thorough!!)
Hope this helps, let me know.
Posted on May 09, 2009
hiltonjug
  • 612 Answers
SOURCE: Fixing an apartment sized GE range - pushbuttons don't respond
I'm not sure what your question is. Are you trying to find out why only one burner works? The top burners are simple and if you can work on it I can tell you how and what makes it works. The burners are as most ele. things. You have a line in, a switch, a load and a ground. The switch has 220v coming in. When you push a button it allows ele from the line to go to the element which is the load. Which button you push dictates the amount of ele that is allowed to go to the load. It should have a OFF, LOW, MEDIUM and a HIGH. If you check the wires between the switch and the element after you push the HIGH, you should show 220v. If not, you have a bad switch. I hope this helps like I stated, I'm not sure what your question is.
Please rate this solution
Posted on Aug 27, 2009
Testimonial: "I'll try it. I'm trying to get the other three burners to work!! I may post again to ask more specific questions later.."
Ice crusher fell apart manual needed to put back together
Go to ;
http://www.whirlpool.com/manuals/
Enter your model number , and hit enr=ter , or click search . Problem solved !
Aug 20, 2014 | Whirlpool Refrigerators
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Jun 03, 2012 | Whirlpool Washing Machines
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
How to fix a fan that goes off when put on higher option
That depends on whether the problem is a bad high-speed contact in the switch or an open winding in the motor. It's more likely to be a switch problem. In the best case, you can spray contact cleaner into the switch and it will work. Otherwise, you may have to replace it.
If you are really handy, you can take the switch apart (you may have to drill out a couple of rivets), polish the contacts, then put it together with some small screws and nuts - probably #2 size. If you do this I strongly recommend using a thread locking compound on the screws so the switch doesn't fall apart while the fan is running. If you can find replacement rivets in that size, that's a better way to go. Some fan switches are glued together or snap together; you'll have to examine yours to see what you have.
May 31, 2011 | Vacuums
Model 41.000-L range hood. Fan is getting electricity (very soft hum), but fan won't turn. Must it be replaced, or can it be cleaned, or ????
Sometimes they can be cleaned and oiled and they will work again...
Cleaning the grease and dust with out ruining the motor is the tricky part...
Take the unit apart as much as possible...spray down the fan part with a degreaser or strong cleaner...let it soak and they spray it down with water to rinse it off...
Then work a few drops of light motor oil into the motor by proping up the fan so that the oil will run down the shaft and into the motor...
then get it running smoothly by working it by hand...
Put it all back together and it should work again...
heatman101
Jan 13, 2011 | Broan-NuTone Kitchen Ranges
The fan fell apart on my M7DH45B2A and I was wondering how to find a part number for the fan to order a new one.
ApplianceFactoryparts.com has the replacement part for the "squirrel cage" for the motor or "fan". Use the Model number to find the parts.
Jul 10, 2008 | Maytag M7DH45B2A Dehumidifier
Kitchen Ranges Logo
296 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
