Question about Magnavox ZV427MG9 DVD Recorder VCR
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
..Additionally there is ONLY ONE coaxial terminal. --And I don't understand whether that ONE goes out to the TV or whether it functions as a Line In from the Cable box. --But then why aren't there 2 (TWO) coaxial terminals? ,,,More importantly, why doesn't the co-axial cable from my DVR XFinity cable box fit into the SINGLE co-axial terminal on the Magnavox recorder?!!
    New Friend:
    Problem Solver:
  • 5 Answers
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Why does neither the co-axial cable from my DVR Ca - 12_5_2012_11_01_29_pm.png
Posted on Dec 05, 2012
  • Mara L Cunningham Dec 06, 2012
    Hi, Sundar--Yes, my coaxial cable is the screw-in kind both from the TV and the XFinity (Comcast) cable box. --But more to my point is that this screw-in cable, which worked fine with my Sony VCR/DVD, and also the same nut-and-screw coaxial cable from my TV terminal, DO NOT screw into the Magnavox coaxial terminal! Also, as I mentioned before, Magnavox has only 1 (ONE) coaxial point! --What do I do about the 2nd (second) coaxial cable ? Something--either the TV or the Cable box will remain disconnected!--Is there someone at the Support Center who can draw me a diagram or tell me why Magnavox has just ONE coaxial terminal? --Otherwise I cannot use this recorder.
  • Mara L Cunningham Dec 07, 2012
    Sorry--but this was not helpful! my coaxial cable is the screw-in kind both from the TV and the XFinity (Comcast) cable box. --Neither yhis screw-in cable, which worked fine with my Sony VCR/DVD, nor the same kind of nut-and-screw coaxial cable from my TV terminal, DO NOT screw into the SINGLE Magnavox coaxial terminal! As I mentioned before, Magnavox has only 1 (ONE) coaxial point! --So what do I do about the 2nd (second) coaxial cable ? Something--either the TV or the Cable box--will remain disconnected! --Is there someone at the Support Center who can draw me a diagram or tell me why Magnavox has just ONE coaxial terminal? --Otherwise I cannot use this recorder.
3 Suggested Answers
SOURCE:
kalamazoo222
  • 285 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Posted on Mar 05, 2011
atang1
  • 734 Answers
SOURCE: I have a Magnavox ZV427MG9
The design of the combo does not support RF output from its internal tuner. You have to use audio video or s-video output to TV. Or you have to add an RF modulator from Philips to output RF channel 3/4 analog connection. Combo RF output is just pass through DTV antenna connection.
Posted on Feb 21, 2012
I'm trying to copy a tv show from my DVR and the recorder keeps saying Recording Error This program is not recordable in +vr mode. What is +vr mode?
Recording mode is set wrong, change it and try again unless there is an anti-copy signal on recording which some money hungry cable companies do to screw with customers.
Sep 01, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
How to hook up a vcr/dvd player to a cable box
Cable box RF output to Combo antenna input. Then use menu in combo to search for cable stations.
Jan 26, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Magnavox ZV427MG9 DVD Recorder  VCR Logo
274 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
