Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Washer won't dispense water
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Does it hum at the water intake cycle?
Posted on Dec 05, 2012
Frigidaire gallery washer
code f 21 mattag 3000 series f21 when goes from 11mins it comes up every time can you help me out thanks
Jul 27, 2013 | Washing Machines
Whirlpool washer model wfw9150ww01 won't dispense bleach
My guess is that the valve that pushes water into the bleach compartment has stopped working. It should be accessable from the top. I have some maytags similar to your machine that i have to remove the front panel to remove a couple screws to lift the top like a car hood. Not sure about your machine though.
Jan 12, 2013 | Washing Machines
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
Why won't my model 110 washer spin?
if it still has water in it check the lid switch,close the lid then open it a few inches and close it again,when you do this if you don't hear a clicking sound the lid switch is bad.watch this video and hope this helps
http://www.youtube.com/watch?v=MFsvLiuTniU
Sep 16, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have a Top Load Washing machine from Maytag, and it is a Neptune. Not entirely positive if it is the same model as the FAV6800AW. I have a load going right now so I don't want to check. Anyway,...
The Bleach dispenser valve may have failed.
Are you into to troubleshooting the issue?
If so I will help. Check to see the washer top is not bowed downward at the Console loaction. If the Pic come thru make sure the water channel on the left side of the lid lines up with the left side (bleach) dispenser valve I'll post a pic but lately the picks won't be displayed. This forum is difficult for DIY support.
If the pics don't come thru Google Neptune TL Washer FAV6800AWW post in the Maytag washer part of the forum for support my time is free as an owner.
Aug 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. They simply won't dispense the bleach from the reservoir. Is there any underlying problem that may cause...
Maybe the water channel leading to the dispenser valve is not aligned......lid bowed? See Pic
""I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. ""
Describe fail......did you replace the valves or a repair service?
If you did the work what troubleshooting did you do on the valves? Did you check for 120VAC applied to the valve in Service Mode? Maybe the relay that applies 120VAC to the valve is not functioning or working intermittently........see pic of schematic of Control Board K3 is the Bleach Dispenser relay that applies 120VAC to that dispenser valve. Is it working 100% of the time? If not it may be a Control Board or connector issue ......but you need to troubleshoot.
Did you power up your old dispenser valves with a 120VAC cheater cord on the work bench to verify operation Open/Close?
I'm an owner not a appliance repair tech but have a electronics technical background.
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener will not dispense in my Gallery front load washer. I've cleaned everything I can get access to and it still won't dispense the softener
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 13, 2011 | Frigidaire Washing Machines
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
