Question about Canon Pixma Pro 9000 MARK II InkJet Photo Printer
Canon pixma pro 9000 mark ii Wont print from front feeder
The printer doesn't seem to recognize that the front feeder is loaded and ready to go... nothing happens when i push the feed switch button. I keep receiving the same error message telling me to open and load the tray, I cant find any obstructions
Canon pixma MarkII pro 9000 has an error 5C00 or purge error?
That is probably some paper or a foreign object inside the machine. Check around the waste station and at the far end of the printhead travel in both directions. Remove any found foreign objects and restart the printer. If there is nothing there to find - it is probable that the is a mis-alignment of the gear train that selects the various functions of cleaning, paper feed, and waste purging. In that case, there is not a lot you can do short of a complete strip down and rebuild with no guarantee of succes.
Jan 30, 2014 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
Canon pro 9000 printer -green tint on all prints
theres an option in the printer options. if you have run the clean printer head option then you may need a new printer head
May 03, 2012 | Canon Pixma Pro 9000 Mark Ii Inkjet Photo...
How to select other cannon printer using EZ photo print EX
If it is a non Canon printer ,I do not believe it can be done. Most software suites like EZ Photo are exclusive to the manufacturer.
Mar 20, 2011 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Feeder problems with Pixma 9500
By having a certified technician do a cleaning on the feed rollers this should fix the problem.
Jun 04, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma Pro 9000 MARK II InkJet Photo Printer Logo
78 people viewed this question
old marine
old marine
