Admiral atw4475vq hums
Just hums does not spin
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Does it agitate?
Posted on Dec 05, 2012
  • 2 more comments
  • gary Dec 06, 2012
    no it fills with watter and when it is suppposed to agitate it just hums. I checked to see if the moter was jamed by fiddling with the motor to transmission union but all rotated freely by hand. it fails to spin up to wring out the water. that cycle justhums as well. it sounds as if the motor is jamed but it isnt i checked twice.
  • Richard Roth
    Richard Roth Dec 06, 2012
    It sounds like the start relay on the motor is bad or weak windings in the motor. I would replace the motor. There is no other cause for this condition. Here is the motor to order.http://bit.ly/11FVGXp That part also comes with a 365 day, any part, any reason return so there are no worries if you should need to return it. Keep me posted.
  • gary Dec 06, 2012
    dear Richard I cannot thank you enough for your help. Hopefully tomorrow I will be able to remove the motor and confirm your assessment. I have never used fixya service, how do I give you points to boost your ratings. I will give all that im allowed to give. Also the fixya service appears to be free at my end. So forgive my curiosity but do you get paid for what you do. I hope so. Once the motor is out I will be able to test. All this may take a few days as I dont move very fast but I will let you know the results of all the work in a follow-up email. Once again thank you. Gary.
  • Richard Roth
    Hi Gary, no I don't get paid on FixYa and I only get a few points for answering questions. FixYa use to be a paid service but went free about a year ago. If you want to buy me a cup of coffee that would be great! Here is the link to it.http://bit.ly/SBjp6g Anyhow, keep me posted and if you should need me I will be around.
Stopped during cycle. will not spin or agitate and makes a humming noise
The humming noise may indicate a worn capacitor on the motor.
Nov 25, 2015 | Admiral Washing Machines
My admiral washer sometime will not complete the spin cycle. If it sits for a while it will eventualy start working. When it is not working the drum will not even move.
1. The timer is failing. 2. The drive motor is disconnected from the drum but will make a hum noise. 3. The motor is failing.
Nov 16, 2013 | Admiral Washing Machines
Filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Jul 03, 2012 | Admiral Washing Machines
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
The agitator will not run the motor only hums. The spin cycle works and pumps out the water.
Sounds like your agitator is jammed with perhaps a sock or something, You may be able to lift the agitator up to clear it.
Jan 09, 2010 | Admiral Washing Machines
My Admiral AAV7000A will fill with water but wont spin or drain, whenever i pull the knob out it just hums.
Could be the timer or the motor. I'd check the timer first. Hope this helps! Ella
Aug 17, 2009 | Admiral AAV7000A
My Admiral lg capicity washer won't agitate or spin
Sounds like the belt is broken. Yes you can fix yourself. Lift top, remove front cover, belt is at bottom, not to hard to replace. If belt is not broke let me know, I will go further.
Jul 17, 2009 | Admiral AW22 Top Load Washer
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
