Question about Intel Executive DQ67SW Desktop Motherboard Socket H2 Micro ATX 1 (INDDQ67SWB3B28
Intel DQ67SW motherboard power on light turns off and on several times during boot
Power indicator light cycles on and off during bootup
  • Richard Elkins
    Richard Elkins Jun 09, 2014
    Hi flyboy95977,
    So why is that an issue? Mine on another mobo do that too and it runs fine.
    Are you experiencing a problem with mobo startup? Does it start or not post at all? Symptoms?
chiplevel
  • 656 Answers
SOURCE: not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
Posted on Nov 29, 2007
SOURCE: INTEL 865 GBF TURN ON PROBLEM
MY HDD IS IDE HDD. AS YOUR ADVICE I SET THE JUMPER CORRECTLY, BUT REMAINS THE SAME PROBLEM. THEN I REPLACE ANOTHER IDE HDD. BUT IT HAS SAME PROBLEM. THEN I REMOVE THE IDE HDD AND JOIN A SATA HDD(COLLECT FROM A FRIEND). NOW THERE IS NO SUCH PROBLEM. BUT I WANT TO USE IDE HDD.PLEASE SOLVE MY PROBLEM. THANKS IN ADVANCE. BYE....
Posted on Feb 25, 2008
ser71
  • 818 Answers
SOURCE: bootup problem
you have problem with the memory (RAM). check it
Sergio
Posted on Mar 08, 2008
  • 94 Answers
SOURCE: No boot, Intel Classic DG31PR, had been working ok
Do you get any beeps sounds when u start your computer? Try removing the memory card and insert it again or try another memory card slot.
Posted on Oct 12, 2008
jell587
  • 447 Answers
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Posted on Mar 06, 2009
Intel pentium - booting up ok, but nothing shows on screen. Pressed F12 came up with error message error setting up the MD3 over power button. Also, unable to locate media direct BIOS table.
If your computer is showing nothing on screen it is not booting up OK. Are there any beep codes being given during bootup? One single beep at the end of the POST sequence is OK, anything more means some kind of hardware error found during bootup. Media Direct 3 is a Dell product that has caused a number of problems on its computers. See Dell MediaDirect . Your option may be limited to contacting Dell support.
Jan 29, 2017 | Intel Computers & Internet
I JUST INSTALLED A NEW MOTHERBOARD IN A PC THAT IM BUILDING FOR A FRIEND. ITS AN INTEL DESKTOP #D945GCPE IT HAS A DUAL CORE PROCESSOR 2GB DDR2,80GB IDE HARD DRIVE. WHEN I TURN IT ON, EVERYTHING WORKS...
During the boot up process are there any beeps? If so how many short or long? 1 short beep is typical of a normal boot indicating no conflicts. What you can also do is unplug or remove any unnecessary peripherals (i.e. Hard drive, cd drive, any expansion cards) So that all you have is the the power supply, monitor cable, motherboard, cpu, and memory plugged in and attempt to boot. If this is successful add one peripheral at a time and boot again untill the boot fails again. This will usually indicate a problem with the power supply, either its faulty or not providing enough wattage to support all the peripherals, otherwise its a conflict with the specific peripheral that causes the failure. IF none of that works attempt to reseat all your connections, cpu socket, memory socket, power supply, and video cable. If all that still fails it is most likely a bad motherboard, its not unheard of to receive a DOA motherboard. As a last ditch attempt you can determine is a faulty video chip or the motherboard itself by installing a pci video card and seeing if its successfully boots.
Oct 10, 2011 | Intel Computers & Internet
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
Had a power failure in my area, my dell desktop was on at time. When I turned it back on I got blue screen which I know is not good. Decided to install new/bigger harddrive since I need to install windows...
Hi, you need to change your primary boot device, try pressing the F1 key during bootup, this will take you to the BIOS screen, from here you can change your primary boot device from HD to CD, save your changes, reboot, selecting boot from CD when it appears during bootup.
Hope this helps
Jul 21, 2010 | Dell (E210882) Motherboard
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Server board SE7591BR2 wont run
did you connect the internal speaker to listen to the bootup beep code?
Jul 31, 2009 | Intel Server Board SE7501BR2 Motherboard
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
Bootup problem
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
81
Mar 08, 2008 | Intel D845GVSR Motherboard
Fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Jan 13, 2006 | HP (D9820-60007) Motherboard
Intel Executive DQ67SW Desktop Motherboard Socket H2 Micro ATX 1 (INDDQ67SWB3B28 Logo
185 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
