Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Update LG model #LFX25960TT Light switches were replaceed brand new.till lights will not go on.
Light were replaced brand new. still not lighting.
    Top Expert:
  • LG Master
  • 9,472 Answers
Ok, you have a problem with the control board and it will need to be replaced. Here is the board to order.
Posted on Dec 06, 2012
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
  • 489 Answers
SOURCE: Refrigerator light not working before fail light
If you have checked the light switch and found it to be working normally, then you will need to replace the control board because the light bulb is controlled by the relay switch. It is not directly connected to the light switch. Good luck
Posted on Jun 19, 2011
I've a LG model 42LV3730, it has no sound and no picture. The ON light switch on a while then off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 27, 2016 | LG 42LC7D-UB Television
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Oct 05, 2012 | Electrical Supplies
The heater light light comes on when first low circulation cycle is pressed but turn off when you press again but only for 20 minutes
It is supposed to. When the heater reaches the temperature you set, it goes off and the indicator light goes off too telling you the heater is off. Soon the temperature drops again and the heater, and the indicator light, comes back on.----This is the working procedure.------ The pressure switch, float switch all needs to be inspected.------- Also what is the exact brand and model of your heater.This will help, to get exact cause of the problem. --------- Keep updated, thanks.Helpmech.
Aug 13, 2011 | Pool & Spa
Refrigerator light not working before fail light started to blink when the door was opened - contacts on door switches OK - believe it to be poor contection - reading low voltage - looking for schematics...
Jun 19, 2011 | LG LFD22860 Bottom Freezer French Door...
LG LRFD22850TT interior light
The relay is stuck shut on the main board. This is covered by an updated board with a heavier relay. Call a dealer and have them check for service bullitens on your model
Jan 22, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Dec 10, 2009 | LG LRFD25850 French Door Refrigerator
Interior light bulbs stay on?
There is a switch on the inside of your frige that has gone bad. The switch is a slide type switch so when you open or close the door it makes the switch slide in and out, making the light come on and off. You need to write down the make and model # of your refrigerator and order a new switch either from the manufacturer or from the place you bought it. Once you have the new switch, unplug the refrigerator, take a flat head screw driver and gently pry the switch from the interior face, pull the two wires off and replace the old switch with the new. The switch is very inexpensive and very easy to replace. Calling a service technician out to do this could cost you more than you expect. If you are not very "mechanicaly enclinded" then just order the switch and have a brother, neihbor, or someone that is mechanicaly savy come over and fix it for you. It should not even take 5 minutes. ;-)
Aug 10, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
115 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
