Question about Polaroid TTM-2003 Combo
Is this TV DVD ready or do I need a Converter Box?
Do I need a converter box for this TV Feb 2009 ?
    Scholar:
  • 89 Answers
Im thinking no. but there is a way you can be sure. look under your menu settings. if under the input settings you see anything about dtv or hdtv you should be ok. the simplest solution is to do a channel search. if you only come up with whole number channels ie, 3, 12, 16. you will need a converter box. if you get channels such as 3.1 12.1 or so on then you will be ok. if you need a converter box. no worries about the price. the government has cupons avalible to offset the price by nearly 80%. simply go to google or ask and type in converter box cupons. the box its self is a breeze to set up. simply plug it into the wall. plug yout anttena wire into the plug on the converter box marked anttena. then take the cord supplied and plug it into the other male connector and into your tv. turn both on and tune your tv to channel 3 or 4. everything should come up. the remote also has a set of tv controls on it.
Posted on Jan 12, 2009
  • K- Brasher May 03, 2012
    What converter box do you suggest? Digital to analog or visa versa. Also, what attenna should I get or use? I don't have cable. Please advise
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Not sure if converter box is needed???
Hello Ann, I will try to help you, well if your for sure about the Manufactur date on the T.V., then yes you will need a digital converter box, also it is suggested to have an outdoor UHF/VHF antenna with coax to attach to your converter box, the old rabbit ears aren't suggested. I hope this helps in getting you prepared for Feb. 19, 2009 when all T.V. stations broadcasting will convert to the new signal. Thank You and Have great day.
Jan 15, 2009 | Sharp 27L-S100 27" TV
TV converter Box
yes it will require a converter box if you don't recieve cable or satellite
Dec 31, 2008 | JVC AV-27D305 27" TV
Will I need a converter box for my Durabrand TV, Model DWT2405?
I'm sorry, but a DWT2405 is not digital. You will need a converter box.
Nov 10, 2008 | Durabrand DWT2405 24" TV
DTV Compatible
If you do not have cable or satellite then you will need a converter box for Antenna only those who will be using antenna for signal will need box.
Oct 30, 2008 | Sanyo DS20930 20" TV
Help
All TVs are ready for change only need converter box if you only have antenna.
Sep 24, 2008 | Philips 60PP9202 60" Rear Projection...
Digital Conversion in Feb. 2009
It looks like you will need a HDTV tuner not a converter box. Here's the link to your manual.
http://www.mitsubishi-tv.com/img/220771
Sep 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
TV Converter Box
the coupons are only good 90 days after they mail out so yes i whould bye them now. as for needing them now to hook to your tv you have till next feb 2009 till you need them but if you have a good tv signal on your stations the dtv box will make them come in almost like dvd picture.real clean and sharp
Jun 23, 2008 | GPX KCL8806DT 7 in. Portable Television
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
DTV????????????????????????
From the side of the carton in which it came:
CONSUMER ALERT: This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009 to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322), or visit the commission’s digital-television Web site at: www.dtv.gov.
The only other thing I could add to this, is that the Post Office in 2009 will get the task of handing out $40.00 coupons to to anyone wishing to purchase a converter.
Nov 15, 2007 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Polaroid TTM-2003 Combo Logo
121 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
