Sound but no picture on my TV.
TV was ok last night ,but this morning when I Turned on the TV there was sound ,but no picture, only a green screen
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
You missed one tiny bit of needed information, what is the brand and model number of this set?
Posted on Dec 06, 2012
get-it-goin
  • 85 Answers
SOURCE: 42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Posted on Feb 27, 2009
  • 30 Answers
SOURCE: Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Posted on Sep 26, 2009
Testimonial: "A quick one to respond with a good answer to the problem."
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
tvtek
  • 1284 Answers
SOURCE: Sound with No Picture
If the lamp hasn't been replaced I would suspect it first. Depending on your full model number of your TV will determine the lamp you need.
Model HDLP61W151YX1 = 260962 LAMP
Model HDLP61W151YX2 = 265103 LAMP
The sticker with the model number will have a service model number that will include the YX! or YX2 at the end of it.
Please take a few moments to rate my answer. Thank you.
Posted on Nov 18, 2009
welcomejee
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Posted on Jul 23, 2010
Sansui volume
Check whether the 'mute' function is ON. If it is On, there will be no sound output, but picture will be OK.
Jan 24, 2013 | Televison & Video
My Avis flat screen HD TV has sound but no picture.
First thing to try is if using a box for signal unplug both that and the set from power for several minutes and then plug back, it is possible the issue will be gone and the set working normal again.
Dec 05, 2012 | Televison & Video
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Black screen only on new LCD
Sounds like the video board when bad. I would say the TV went defective. Use the 90 day warranty to exchange for a new one.
Always use warranty at this point because the newer TV coming out in these days have very lame warranty.
Rate me, please
Feb 02, 2009 | Televison & Video
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
No picture, sound ok
Rca has been known to have bad solder joints in the deflection circuits. Usually around the flyback and transformers.. check it over real good. Just be careful as you can still get shocked after the powers removed the capacitors and picture tube will hold a charge in them.
Jan 21, 2008 | RCA F36649 36" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
