Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Screen flash envision 7100e flashes on and of every couple of minutes for about 2 seconds. any ideas??
CONQUER SPEEDHACK
Posted on Jan 12, 2009
Envision monitor EN-7100e color is screwd up.
Unfortunately this monitor has captived VGA cable, you cannot easily replace it. Try moving the cable around to see if you will get normal color back.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001218.pdf
http://s807.photobucket.com/home/budm/allalbums
Apr 12, 2010 | Envision EN-7100e 17" Flat Panel LCD...
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
My Envision 9410 Monitor flashes on and off. You see the picture fine, but then it goes to a black screen and then back to seeing desktop. The power light goes on and off while this is happening. Is...
Its either going to be the inverter or the lcd going back and it can't keep the screen lit.
Also I've seen it where the capacitors on the power board go puffy and they need to be replaced.
It will be one of those three things.
May 15, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN8500 inverter
no you cant change it yourself because there need some tehnical knowlege so better you buy new one
Dec 09, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision LCD
That mean your logic board of the LCD need repaired or replaced.
Apr 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
70 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
