Question about Bosch Exxcel WFO 2264 Front Load Washer
F61 code door won't open
    Top Expert:
  • Bosch Master
  • 9,472 Answers
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
Posted on Dec 05, 2012
  • Jasveer RIYAIT Dec 06, 2012
    Thank you very very much. It worked. The machine is up and running again. Thanks to you. Take care
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
Sep 02, 2012 | 2000 Buick LeSabre
Siemens WM14S392GB - error F61. Help to fix please.
Error E61 means that the door is locked but the sensor is showing as still open.
You may have a faulty door sensor.
May 07, 2012 | Washing Machines
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
Wireless keypad won't accept our original code. Door won't open. When I enter the code the backlight on the keypad blinks rapidly. I need help. I have no other way to get in my...
Sounds like the receiver in your opener has quit working. Unless you break in you need to call a door technician. They can drill a hole in the door, use a special tool to pull the manual release and open the door. You should then have them install a keyed manual release if this ever happens again. They can also repair or replace your opener.
Jun 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
Im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
Jan 24, 2009 | Audio Players & Recorders
Bosch Exxcel WFO 2264 Front Load Washer Logo
1,650 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
