Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
Tracks playing at the wrong pitch and speed
I have some trks that will play perfect in itunes and on my ipod, however when ipod is in the idj2 some trks are palying at the wrong speed and pitch.I went to the mode button and tried to adjust but I have not been able to resolve this problem.
    Scholar:
  • 58 Answers
This sounds like a difference in the sampling frequency.  Music recorded at 48Khz must be played back at that frequency or there will be a significant difference in speed and pitch during playback at 44.1Khz. I first noticed this when it occurred to me when recording on digital audio tape.  Ipods and minidiscs and mp3 recorders can record at high sampling frequencies like 48K.  Cds are all recorded at the standard 44.1K sampling frequency.   Check the source of your recordings and it should follow a pattern that leads to your current results.       I do not have enough information  on how your music was transferred to tell you more at this time, but I am very confident that differences in sampling frequencies of your source material are causing the pitch differences you are hearing.   Without knowing exactly the sampling frequencies of each piece of equipment you used to record these songs it will be next to impossible to give you a very specific solution, so I hope the info. I have shared helps you to figure it out.  Best regards and good luck!   Michael Mittelsdorf
Posted on Jan 12, 2009
Numark idj2 how to cue tracks
Pause on the point you want to be the CUE. Press play from this point and the point now changes to being CUE.
This is unlike most CDJs.
Sep 06, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have a numark idj2, i can get music media off itunes the media records to my itunes libriary and ipods but will not go into the numark idj2, some of the media appears on the numark libriary but when you...
are the files that you have compatable with your new device. sometimes certain devices can't read the format of the file. not all mMpeg or Jpeg files are compatible with different devices do you have a usb cchord that came with your device and a cd to install the driver in the computer?.... my suggestion is to down load all files from the ipod to your computer. install the driver and the computer will be able to sync your files and their format to your new device...please rate this good luck
Sep 01, 2008 | Audio Players & Recorders
Just purchased iPod Classic 160GB, but it will not play properly via my Hyundai i20 connection. It will only seems to recognise and play 3 tracks (I have nearly 3,000 on the iPod!). The iPod screen...
Please note that ipod's generally uses itunes to load songs. Make sure u have an updated itunes installed in your system, after that, what you have to do is open the music folder of the songs u want to load and also open the itunes with your ipod detected, then simply drag from the music folder and paste in the ipod of the itunes. Once again, you need an itunes to be able to access and load your ipod. Goodluck.
Mar 26, 2011 | Apple iPod shuffle 3rd Generation MP3...
I want delete songs from idj2 pls help
There are no songs on the IDJ2
Only on your Harddrive / USb stick or Ipod.
If you want to play songs via the IDJ2, you need the librarian software for using the IDJ2 in combination with you songs.
Dec 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Can't get the ipod touch to play on the docking station
I had the same problem. Look at the documentation site of Numark
Ipod touch isn't supported for mixing (1st gen is supported for Direct play)
Source:
http://www.numark.com/stuff/contentmgr/files/2/dd1ffd47d0ee2aec5d8ef3afa92e0992/file/ipod_compatibility_numark_v1.6.pdf
May 16, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Unable to play songs on ipod-nano 4GB
You need to restore the ipod, Please refer to the manual or itunes help.
Apr 19, 2009 | Apple iPod nano
My ipod wont connect to the IDJ2
Is the ipod charged? I have had the same issue, because the mixer charges as it plays i have had to wait a few minutes and tryed again. Hope this helps I use a thirty gig as well as a nano for a back-up
Feb 16, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
IPOD TOUCH DOES NOT PLAY
instead of using your itouch in the ipod deck, plug it to the white cord used to transfer music to your pc, and plug it in the usb dock, it should work because i've tried it with the iphone 3g
Feb 05, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
When docking it takes too long transfering data from ipod to idj2
if you have a PC, you're better of preparing a library for your USB/IPOD devices with Librarian 1.50, but only if you are running 1.09(a) firmware on the IDJ2. This is the preferred and quicker way...
Do an upgrade if this is not done yet. Go to
http://www.numark.com/contentmgr/showdetails.php/id/1230/tt/5
for downloading the files.
When rerunning the librarian(for instance when adding tracks), choose normal mode. It will add every playable track. (you could try this out on an USB stick with some tracks on it for testing purposes).
If this doesn't work, you could have a corrupt library, and have to rebuild(choose advanced in Librarian). Also, when you have created with earlier versions of IDJ2 firmware, then you have to rebuild the whole library.
Numark stated on their forums, when connecting a device, to never choose update, but load instead. It can use mp3/wav/non secured aac files, but not wma..
If there are any other questions, you can also send an e-mail to numark. They are reasonably quick with their responses.
regards
Jack
Dec 26, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark idj2
ok try this do you have a master rest of the idjr? if you do use it and see if this will re initialize the device.
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
216 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
