Water got in my cable box - Computers & Internet
    Top Expert:
  • 14,553 Answers
Get the box exchanged and do not mention water got to it--tell them it stopped working.............
Posted on Dec 05, 2012
2000 oldsmobile bravada heater control valve location
If you are looking for some sort of water valve that diverts water to/from the heater core, forget it. They don't exist anymore. They went away shortly after the widely adapted use of air conditioning in today's modern cars. Now, hot coolant is routed thru the heater core at all times, but is controlled by a cable-operated, or vacuum operated "blend door" located inside the heater box. If you are not getting heat to the vehicle, there are a few possible problems:
1. Bad thermostat - thus low coolant temperature and lack of heat.
2. Clogged heater core - no water flow thru core, thus no heat.
3. Broken control head - loss of cable or vacuum actuation of blend door.
4. Broken heater box/vacuum tank - no actuation of blend door.
Of the items listed above, based on the age of the vehicle and the likelihood of occurrence, I would investigate them in the order of 2, 4, 1, 3.
Jan 20, 2016 | 2000 Oldsmobile Bravada
My son spilt a lttle water in the holes on top of my cisco cable box i let it dry but it still wont turn on is there a reset button or do i need to get a new box
You probably need a new box. Contact your cable company. I might not mention the part about your son and the water....
Mar 01, 2015 | Cisco Computers & Internet
How do I fix a wet fuse box in an engine compartment of a 2003 chevy avalanche that had vinegar and baking soda spilled on it, now the truck wont start?
Sam , vinegar and baking form a type of acid !!!!!!!!!!!!!!!!, ,baking soda by it self will neturalize the vinegar ,I'm not sure why you were doing this, no matter ,disconnect BATTERY, flush with pleanty of cold water and baking soda followed by just cold water, if you have compressed air that will help to dislodge water and hair dryer will help to .good luck.
Woody
Sep 22, 2014 | 2003 Chevrolet Avalanche
How to enter ariston water heater with cable
on the power supply box there should be a knock out plug.
Jul 08, 2014 | Water Heaters
I have to reset every couple of hours, i get disconnected for the wireless
First , Check/swap ALL cables, If you are sure it not inside. Contact your ISP and have a tech come out to analyze the signal, it may be outside. I had a similar issue I traced the cable all through the house to the cable entrance, the tech found a underground box that had been run over by a large lawn mower breaking the box allowing water to enter.
Dec 27, 2012 | Zonet ZSR3104WE 802.11G MIMO WIRELESS...
Mazda tribute 2003 transmission not working. i can move the into D 2,1 R but car wont move an inch
since you had a water mixed with transmission fluid,the only thing I personally believe that is no need to continue playing with as the water is the worst enemy of the automatic transmission. makes all the o rings to expand and corrosion . It happened to me a while ago and I reconditioned the Gear box.
Aug 10, 2012 | 2003 Mazda Tribute
2004 pontiac grand prix, gtp , water pump replacement.. Do you have to remove the fuse box to get access to remove the pump
no, here is procedure according to autozone.com
3.8L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine coolant.
  3. Remove or disconnect the following:
    Negative battery cable. Drive belt Water pump pulley Power steering pump and move it aside Water pump
    Fig. Exploded view of the water pump assembly mounting-3.8L engine
To install:
  1. Install or connect the following:
    Water pump using a new gasket and torque the long bolts to 25 ft. lbs. (34 Nm) and the short bolts to 16 ft. lbs. (22 Nm) Water pump pulley and torque the bolts to 115 inch lbs. (13 Nm) Power steering pump and torque the bolts to 25 ft. lbs. (34 Nm) Drive belt Negative battery cable
  2. Fill the cooling system.
  3. Start the vehicle and check for leaks, repair if necessary.
Sep 29, 2010 | 2004 Pontiac Grand Prix
MY DISH washer electric supply wires are cutdown and water pipe of dishwasher cutoff and i want its diagram input which is help full to connect the circut
Hi .. the electrical input to the dishwasher should be a 3 wire cable, black, white, green/bare. The connection is generally into a small metal box just behind the kick plate on the right side of the front of the washer. The cable gets run thru a cable connector to keep the presure off the connection. The connection is black to black, white to white, green/bare to a ground screw in the connection box.
Jun 21, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
Went throgh a large puddle a week ago and now the car want start
Probably water in the relay box or multiple sensors, you can displace the water with electrical contact cleaner. You will need the chiltons book for the vehicle or have it to be safe, unplug your negative battery cable before doing anything. Remove the top of relay box and inspect for water damage, you can then go sensor to sensor, unplug and blast both sides, shake out excess let dry for a few minutes and replug.
This may or may not help you, it is what i would do first.
Aug 02, 2008 | 1996 Volvo 850
Computers & Internet Logo
David Payne
David Payne
