Question about Panasonic PT-52LCX66 Projection Television
The reset lamp timer instructions do not work on my Panasonic. What do I do now?
I have used the suggested solution several times of holding the volume down button on the TV and the 0 button on the remote, but it has not worked. What now? alhofland@sbcglobal.net
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Call Panasonic customer service unless they told you to do what you tried.
Posted on Dec 06, 2012
  • 47 Answers
SOURCE: Lamp timer reset
You will need the remote that shipped with the television. Take it with you up to the television then press and hold the VOL- button on the TV and the SPLIT button on the remote. Message should say "lamp time was reset to 0". Make sure the remote is in TV mode and aimed at the TV's IR sensor.
Posted on Mar 09, 2008
SOURCE: projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Posted on Feb 02, 2009
  • 81 Answers
SOURCE: resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Posted on Nov 19, 2009
pabloloco
  • 2335 Answers
SOURCE: MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Posted on Apr 11, 2010
pabloloco
  • 2335 Answers
SOURCE: How do you reset lamp timer on on panasonic
I hope that helps.
Posted on Apr 15, 2010
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
How does one reset the lamp timer. modelpt-56dlx25
Panasonic2.gif Lamp timer reset.
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 12, 2009 | Panasonic Televison & Video
LP 50 Panasonic Projection TV just replaced the lamp but don't know how to reset lamp clock
Panasonic Lamp timer reset.
asnowman
Oct 07, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Mar 16, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Feb 15, 2008 | Sharp XV-Z2000 Multimedia Projector
Projection lamp timer reset
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-52LCX66 Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
