Question about RIM BlackBerry Curve 8520 Smartphone
Trackpad not working need to security wipe curve8520
    Master:
  • 368 Answers
Phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 06, 2012
How to factory reset
Follow below steps:
From the home screen, scroll to the All tray and press the trackpad.
Scroll to Options and press the trackpad.
Scroll to Security and press the trackpad.
Scroll to Security Wipe and press the trackpad.
Scroll to the desired options and press the trackpad to check or uncheck as desired.
Enter blackberry in the text field.
Scroll to Wipe Data and press the trackpad.
The handset will completely reset and restart.
This will take several minutes.
Jan 04, 2014 | Blackberry Curve 9310 Black Smartphone -...
My blackberry scroll pad is not working, and i can't scroll anywhere. i took it to the shop and the man told me it was a hardware problem, i have pop reset it and soft reset it and nothing seems to work. i...
hi Titchypink.
this is all i could find out,hope it helps you out.
Trackpad, trackball, or keyboard not working on a BlackBerry smartphone running BlackBerry OS 7.1 and earlier Article Number: 000029640 First Published: April 26, 2017 Last Modified: April 26, 2017 Type: Support
Environment
  • BlackBerry smartphones running BlackBerry OS version 6 to 7.1
  • BlackBerry smartphones running BlackBerry Device Software 5.0
Back to top ?
Overview
In some situations, a BlackBerry smartphone with a trackpad or trackball may experience issues with sensitivity, latency, or scrolling. Additionally, the BlackBerry smartphone keyboard, or other buttons may be unresponsive.
Back to top ?
Cause
This issue might be caused by one of the following:
  1. The trackball/trackpad sensitivity needs to be adjusted.
  2. Make sure the trackball/trackpad is not affected by a software freeze or an application freezing.
  3. The BlackBerry Device Software is out of date and requires an update to resolve the trackpad, trackball or keyboard issue.
  4. The physical trackpad, trackball or keyboard hardware is malfunctioning.
Back to top ?
Resolution
Resolution for Cause 1
Complete the steps in Article 5447 to ensure the trackball/trackpad sensitivity is correctly.
Resolution for Cause 2
For BlackBerry smartphones running BlackBerry OS version 6 to 7.1 using a trackpad, complete the following:
  1. From the Home screen, select Options.
  2. Select Typing and Language.
  3. Select Trackpad Sensitivity.
  4. Ensure Audible Roll is selected.
  5. Rapidly roll the trackpad up, down, right, and left.
  6. If an audible click is heard while not responding, proceed to Resolution for Cause 4 as this could be a software related problem.
For BlackBerry smartphones running BlackBerry Device Software 5.0 using a trackball, complete the following:
  2. Select Screen/Keyboard.
  3. Ensure Trackball Audible Roll is selected.
  4. Rapidly roll the trackball up, down, right, and left.
  5. If an audible click is heard while not responding, proceed to Resolution 4 as this could be a software related problem.
  6. If an audible click is not heard, the problem may be related to a hardware issue. Please contact the wireless service provider for additional steps.
Resolution for Cause 3
To update BlackBerry Device Software using BlackBerry Desktop Software see, Article 11320.
or
To update the BlackBerry Device Software on the BlackBerry smartphone visit http://www.blackberry.com/update/
Use the BlackBerry Virtual Expert diagnostics application. For more information, see Article 35973.if not try this link. blackberry scroll pad is not working Google Search
Nov 27, 2017 | RIM BlackBerry Curve 8520 Smartphone
How can I reset my blackberry curve8520 myself?
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
Jan 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Reload software552
How to reset BlackBerry Curve 8520 to factory settings:Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Nov 25, 2010 | RIM BlackBerry Curve 8520 Smartphone
Macbook unibody late 2008 model having trouble with the trackpad click. sometimes it works but most of the times it would not function
Apple menu (top left) > System Preference > Trackpad.
Is were you find the settings for the trackpad. You will need to have to find your sweat stop within the settings. play around with the settings.
Jul 18, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
The trackpad does not work anymore. How can I fix it?
You would need to take the phone apart and replace the trackpad. You can find a trackpad on ebay for about $12-15. If you are interested you can contact us and send it in for us to fix it. If you buy the trackpad yourself we would just charge you for labor, otherwise we would charge you for the trackpad + labor.
www.usedcellphoneshop.com
May 18, 2010 | RIM BlackBerry Bold 9700 Smartphone
Trackpad on Blackberry Curve 8520 has stopped working and whenever the phone is switched on the trackpad heats up considerably.
Sounds like your trackpad needs replacement. The part is available on major auction websites for around $10. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
May 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
Trackpad on Blackberry Curve 8520 has stopped working, and whenever the phone is switched on, the trackpad heats up considerably.
i had the same prob with my bb 8520 .. i have got this info 4rm a site n it waz a video telling u how to remove ur trackpad ... i have removed my trackpad according to the video n cleaned the sides n the trackpad .. n connected it carefully ..Now it works Perfectly ! its not hard but its risky .. n now have a look at the video ' http://www.youtube.com/watch?v=-HgLXRgedvI ' believe me it really works :D !
Mar 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
I keep getting an app error 523, i removed all of
try a factory reset:
How to reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Mar 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
RIM BlackBerry Curve 8520 Smartphone Logo
59 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
