Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
    New Friend:
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Posted on Feb 09, 2013
    New Friend:
    Problem Solver:
  • 13 Answers
There probs be an air leak in the hose were it joins the motor iv had the same prob somtimes a change in hose works or new seal in motor hope this helps
Posted on Dec 05, 2012
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Why will water not flow through hose into the spray gun with the washer not started as well I started the power washer and the water still does not come out.
My Craftsman pressure washer has a filter in the hose tp the pressure wand. I found I must have had some dirt in my garden hose and these filters were plugged. No pressure at all till I cleaned them out.
Jul 04, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Pressure washer won't deliver pressurized water.
sounds like you have a blockage maybe in your water hose ,ideally your water hose should be around 25 feet..or you may have an o ring in the gun where the tip goes.. is broken..that will affect your pressure..check also filter where water hose connects to the pump make sure thats clear
Sep 30, 2017 | Briggs & Stratton Briggs Stratton 1800...
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
I pressed cancel & it still wont work! its flashing "H" & "F"
Press Cancel twice. Then check your water inlet. Are the valves open? Unplug the washer. Then close the valves and disconnect the water hoses. Check the filters in the hoses (if present) and at the washer inlets for objects clogging the filter. Make sure that the hoses aren't kinked when you reconnect them to the washer and the incoming water valves. Make sure that you have sufficient water flow coming into the washer. The pressure must be above 20 PSI . Replace the hoses. (If you use certain anti-flood hoses, they will seal and block water flow when they notice a pressure issue that could be from a water leak.)
Plug the washer back in, reselect your wash cycle and then press Hold to start. If the FH error persists, then you probably have a problem with the inlet valve or the pressure switch for the valve. Call for service if the washer is under warranty or you aren't sure that you can replace the valve. (See the parts list labeled Top and cabinet parts.)
The manual and parts list for the Duet GHW9150P washers are available from Whirlpool here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFlibuKNJvC4qU4ramPrjJ75r2vuMTp0sZ%2F5gVjei80pPz5Qc1hYJgPeg&ddkey=http:OCManualsLiteratureSearchResultView . There are several models so look for yours.
I hope this helps.
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Builds up pressure won't spray
pressure relief valve is faulty. replace.
Aug 10, 2009 | Garden
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
545 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
