Question about Kenmore Washing Machines
Kenmore front load washer leaking by liquid despenser
Water spouting from liquid despenser
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 05, 2012
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 530 Answers
SOURCE: Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Posted on Mar 26, 2009
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Posted on Apr 26, 2009
  • 382 Answers
SOURCE: kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Posted on Dec 16, 2009
SOURCE: kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Posted on Jun 01, 2010
Testimonial: "good to go "
Leaking from under front of machine
Hello there
Please read the entire solution to best match your problem I have provided below
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
I will post the rest of the solution in the next comment
Dec 26, 2010 | Kenmore 24032\24036 Top Load Washer
Cant find the flow meter on my he 3t washer
the flow meter usually connects to the dispenser, it is real small and it has i believe mercury inside of it,,,type of liquid.
Sep 16, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Bleach and fabric softner despenser liquids not being used.
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Leaking when wash starts
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Kenmore washer top load heavy duty 80 fluid leaking
    It's rusty Water probably the water pump housing is cracked might be replaceable need to take a look at it or call Kenmore for the part
    Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
    check teh rubber seal on teh front door. They sometimes leak down the front of the door.
    Jan 14, 2008 | Kenmore 44832 Front Load Washer
    Washing Machines Logo
    252 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
