Question about Dell 924 All-in-One InkJet Printer
Paper jam dell 924 inkjet printer
The first page printed with a little bit of wrinkle at the bottom. the second page got fed in however, never came out. I cannot see the paper jam. powered down the printer, opened up the case and near
the ink cartridges. nothing, no paper.
where else could the paper disappear?
    President:
  • 8,637 Answers
Is there a door or access on the back of the printer? Some printers can be accessed there.
Hope this helps. Bud
Posted on Jan 22, 2009
I was printing a report and had one page left to go and I noticed that it was out of paper. So I got some paper and put it in the paper slot. The printer fed about 6 sheets in a one time and that caused...
there is still paper stuck in the printer. open up the front of the printer (as if you were changing the ink cartridge) and remove the paper. Then turn the printer off and on. Good luck.
Feb 26, 2011 | Dell 924 All-in-One InkJet Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Clear the paper jam
Read page 58 of the manual:
http://docs.google.com/viewer?a=v&q=cache:Dgrfa-DsGegJ:support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf+Dell+All-in-One+924+InkJet+Printer+manual&hl=en&gl=us&pid=bl&srcid=ADGEESg00jswAG8BUv_6xd_VirkAWfwgO-c6HNzth5TbSqEhWIU5GYZ3rPvKmAbkl7Cckn5TUXo3b5hVOOie0UmIEZD_VJXjyh4X9e_c9xfxzgl_DiBOFJ6t1ZA0ZNvbZeGuXLemFJ4A&sig=AHIEtbSz3nSdI0cNmZKMsYBqWe5j-rwEew
Jan 18, 2011 | Dell 924 All-in-One InkJet Printer
My Dell 924 CLAIMS it has a paper Jam and does NOT.... it will not clear this out and I can't print anything! Help!
check the feed rollers for a dirt build up , they can be cleaned with a damp cloth, the probable cause is slipping feed, the printer expects paper and none is fed due to the slipping of the rollers.
look where the front edge of the paper sits, there are rollers there that bring the paper into the printer, clean them.
Jan 11, 2011 | Dell 924 All-in-One InkJet Printer
Non-existent paper jam
There is almost certainly an optical sensor somewhere that either has a tiny bit of paper or dust in it. Try blowing dust out of the insides of the printer with a shop vac set to blow air out. Also try disconnecting/reconnecting the optical sensors throughout the paper path of the printer. Only do these things with the printer disconnected from everything.
Nov 01, 2009 | Dell 924 All-in-One InkJet Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Inkjet Printer False Paper Jam
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
