Question about Nikon 26302 Coolpix S6300
The flash doesn't work
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Posted on Mar 21, 2008
SOURCE: Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Posted on Feb 12, 2009
  • 10 Answers
SOURCE: Pictures too dark. Shutter operating too slowly.
Are you in auto mode? If it is manual then it is possible that the settings are not correct for the light. You can look at the meter to see what the camera thinks about the exposure.
It sounds as if your subject is too dark. Does this happen when the area is brightly lit? Does the flash fire?
Posted on May 07, 2009
97F350diesel
  • 1326 Answers
SOURCE: I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Posted on Aug 06, 2009
richard191
  • 691 Answers
SOURCE: WHY DOES MY NIKON D60 BUILT IN FLASH FAIL TO WORK
Hello
Thank you for using
FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
Bulldog deluxe 500.....can't get into programming mode.
I have been having the same problem. I was searching for the solution and found your question. Yesterday I tried the last thing I could think of and it worked. I unplugged everything from the black module. I left it over night I was coming home from work and wouldn't be going out to my car anymore but 15-30 minutes should be fine. Once I plugged everything back in, I was able to get into a programming mode. I was trying to change the start time. Hope this helps!
Dec 06, 2011 | Vehicle Parts & Accessories
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
My sony cybershot dsc-w310 is not flashing
I'm sorry that the built in flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the Handbook to get the information to change the setting.. Click hear to download the Handbook if you don't have one handy.
If the issue persists, please Initialize the Camera. To initialize the Camera, please use the Initialize option under Main Settings option on the Camera. Also make sure that the battery is fully charged.
If the issue persists after performing all the above mentioned troubleshooting steps, service is required. Click hear to locate your nearest service center.
Thanks for understanding. Please let me know if you require any clarifications.
Thanks for using Fixya...
Aug 07, 2011 | Cameras
Trying to start the car I get "instant draw-down" of the battery and the car won't start--the battery is fully charged
the battery may be fully charged but that doesn't mean that it doesn't have a weak cell, next time you go to start the engine remove all of the battery filler caps (if it has any) & get someone to look into the holes to see if they can see if any of the cells are bubbling,if any are the battery is faulty & needs to be replaced......hope this helps......cheers.
PS. don't get your eyes to close when looking into the holes of the battery,it might be safer to use a mirror.
Jun 28, 2011 | 1990 Plymouth Horizon
Wont start can jump it but later on it wont start again
You've got a bad battery - it just doesn't have the required cranking amps anymore. Replace your battery.
May 27, 2011 | 2003 Chevrolet Impala
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon 26302 Coolpix S6300 Logo
440 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
