Question about AEG Ovens
Aeg competence b1180-1 cooling fan will not run but everything esle works fine i have changed thermal limitor not sure if i put wires back in right place could that be cause of problem
barkencoa
  • 3463 Answers
SOURCE: aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven is AEG Competence, single oven, fan assisted,
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Posted on Jan 06, 2010
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
barkencoa
  • 3463 Answers
SOURCE: AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 24, 2010
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Hope this helps.
Feb 05, 2010 | AEG Ovens
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Aeg competence b2190-1m oven not heating
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Aeg competence oven fan not working
Plz leave feedback.
Dec 09, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Ovens Logo
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
