Question about Pioneer Audio Players & Recorders
Vsx-d814 pioneer receiver has no sound from subwoofer
It worked unhooked every thing to move room around set back up and now no sound from sub
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
SOURCE: pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Posted on Feb 07, 2010
Pioneer Elite VSX-92TXH subwoofer pre out does not work
These receivers have a history of having broken connections on the subwoofer jack. Would have to go in for repairs.
Apr 09, 2013 | Pioneer Vsx-92txh Elite Home Theater A/v...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
May 13, 2010 | Pioneer VSX-815-K Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
Pioneer vsx-d814 will not power on after power surge
Mar 21, 2008 | Audio Players & Recorders
Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
Jan 24, 2007 | Pioneer VSX-D606S Receiver
136 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
