Question about Whirlpool Dryers
Dryer won't spin
Approximate 2006 Whirlpool front load dryer will turn on, heat, but will not dry clothes. Any suggestions on how to fix?
    Top Expert:
  • 14,553 Answers
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Posted on Dec 05, 2012
  • 43 Answers
SOURCE: Whirlpool dryer does not automatically shut off.
your timer motor.
Posted on Apr 25, 2009
  • 1003 Answers
SOURCE: dryer turns off too soon
REPLACE THE FAULTY TIMER
Posted on Jan 18, 2008
  • 10865 Answers
SOURCE: Dryer turns on and spins, but will not heat and dry clothes
Here is a quick course on the reasons why a gas dryer won't heat. If you are not mechanically inclined you will have to get a repair man because none of these reasons are quick fixes.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on May 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
canbruce75
  • 1776 Answers
SOURCE: Whirlpool Electric dryer LE5800XSW3 won't dry
This repair will most likely be much cheaper than buying a replacement, unless you just want to make a jump to gas. First, check the venting for the dryer. Clogged venting can cause prolonged drying times. It could also be caused by a blown thermal fuse, bad heating element or high limit thermostat. If the venting is clear all the way to where it exhausts to the outside, then I would suspect bad thermal fuse or high limit thermostat. They can be tested using a multimeter or ohmmeter. It is best to replace both the thermal fuse and the high limit thermostat at the same time and they often come from the parts supplier as a set. I'll attach a photo of a fuse/thermostat for reference. Really sorry for your trouble and I hope this helped some. Best wishes.
Posted on Sep 23, 2009
Testimonial: "Thank you for your detailed response . . . "
LG DLG2251W won't heat up
Your post is from 2008 but I am having the same problems with this dryer, same model. This is an LG problem, for crying out loud LG ---- GET IT FIXED. No more LG dryers for me. My $300 Kenmore works like a charm.
The first LG dryer they sent me I thought was a lemon. They came out and replaced the motherboard on the brand new dryer. They came out again and couldn't figure out why it wouldn't dry my clothes, and the second time they gave me another brand new dryer. Same problem with this one and all brand new perfectly clear ducts. Really?????
Google "lg dryer spins but no heat" on youtube - he explains how to get to the sensor and reset it, but still trying to figure out where to find it on my model. I can't believe I have to go through all of this with a $1000 machine!! Never ever again. Avoid LG dryers at all costs. It takes me HOURS to dry a load of laundry. Wanna throw a dry piece of clothing in the dryer for a few minutes to get the wrinkles out? hahaha think again. The heat will never come on even with the manual (non sensor) setting.
Again = AVOID LG DRYERS AT ALL COSTS. It's not worth the headache.
Nov 25, 2012 | LG DLG2251W 27" Front Load 7.1 Cu. Ft. Gas...
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool dryer won't dry
If your dryer spins and heats properly and the clothes don't dry, then very simply put, the moist air is not being taken away. If your drying temp is adequate, then the problem is with the exhaust. Go to where the air is being exhausted outside your home, if working properly, when you put your hand on the air coming out, it should get damp very quickly. And ALWAYS clean the lint trap after every load!!!!
Jun 21, 2009 | Dryers
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
