Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I have 4 wires colors are red, green, white, and blue
I need help installing......
  • 59 Answers
IMPORTANT THEASE ARE TRADE STANDERD
red to r
green to g
white to w
yellow to y
  • R: It is the main transformer low voltage wire. It comes off of the transformer and feeds to the thermostat.
  • Y: It is the compressor wire and is connected to the other side of the compressor.
  • G: It is for fan. It is connected to one side of the fan relay and there is a common wire on the other side.
  • W: It is for strip heat. The strip heat has a relay and common side. The wire is connected to the other side.
  • Posted on Jan 22, 2009
    I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
    see connection colors below and let me know if you have questions.
    2004 Nissan Sentra wire colors aftermarket radio wire colors
    Car Radio Constant 12v+ Wire: Pink, yellow
    Car Radio Switched 12v+ Wire: Blue, red
    Car Radio Ground Wire: Gray, black
    Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
    Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
    there is no factory amplifier wire, blue (tape off radio wire)
    Left Front Speaker Positive Wire (+): Pink, white
    Left Front Speaker Negative Wire (-): Blue, white/black
    Right Front Speaker Positive Wire (+): White, gray
    Right Front Speaker Negative Wire (-): Black, gray/black
    Left Rear Speaker Positive Wire (+): Light Green, green
    Left Rear Speaker Negative Wire (-): Violet, green/black
    Right Rear Speaker Positive Wire (+): Blue, violet
    Right Rear Speaker Negative Wire (-): Pink, violet/black
    Aug 21, 2011 | Car Audio & Video
    I need speaker wire color codes from in dash the colors i have are blue and white gray black tan green and black brown and green white and pink blue and pinik
    This should be what you need
    Constant 12v+ Wire: Green/Violet
    Switched 12v+ Wire: Yellow/Black
    Ground Wire: Black/Light Green
    Illumination Wire: Light Blue/Red
    Antenna Trigger: Orange/Blue
    Amp Trigger Wire: Blue (If Equipped)
    Left Front Speaker Positive Wire (+): Orange/Light Green
    Left Front Speaker Negative Wire (-): Light Blue/White
    Right Front Speaker Positive Wire (+): White/Light Green
    Right Front Speaker Negative Wire (-): Dark Green/Orange
    Left Rear Speaker Positive Wire (+): Gray/Light Blue
    Left Rear Speaker Negative Wire (-): Tan/Yellow
    Right Rear Speaker Positive Wire (+): Orange/Red
    Right Rear Speaker Negative Wire (-): Brown/Pink
    Dec 26, 2010 | 1995 Ford Explorer
    What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
    Red = ground
    black = ground
    Grey/blue = Left rear (+)
    yellow/black = ignition 12v
    white/purple = right rear (-)
    green/black = (could this be green / violet?) than it is 12v constant
    blue/red = illumination
    orange/green = left front (+)
    white/green = right front (-)
    blue/white = left front (-)
    brown/yellow = left rear (tan / yellow) (-)
    green/orange = right front (+)
    orange/red = right rear (+)
    blue = not used
    Nov 10, 2010 | Ford Car Audio & Video
    Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
    Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
    Constant12V+ Green/Yellow
    Switched 12V+ Yellow/Black
    Ground Black/Light Green
    Illumination light blue/red
    Left Front + Orange/light green
    Left fRont - light blue/white
    Right Front + white/light green
    Right Front - dark green/orange
    Left Rear + gray/light blue
    Left Rear - Tan/Yellow
    Right Rear+ Orange/red
    Right Rear - Brown/Pink
    Apr 13, 2010 | Car Audio & Video
    Just need a diagram showing how to install the
    If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
    However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
    What/ Color/ Where:
    Constant 12V+ White Ignition Switch Harness
    Starter Black/White Ignition Switch Harness
    Ignition Black/Yellow Ignition Switch Harness
    Accessory Yellow Ignition Switch Harness
    Tach Blue Distributor
    Brake Switch Green/White Brake Switch
    Trunk Pin Green/Black (-) Above Fuse Panel
    Parking Lights Red/Black Above Fuse Panel
    Head Lamp Red/White Steering Column
    Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
    Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
    Door Unlock Green/Red (-) Driver's Running Board
    Horn Wire Blue/Red (-) Steering Column, use Relay
    Windows Up LF=Red/Blue, RF=Blue/Yellow
    Windows Down LF=Red/Yellow, RF=Blue/Green
    Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
    What colors go where sony cdxf5700 install to
    The aftermarket wiring colors are universal so this is for your Sony
    Battery ---yellow
    12 volts accessories-----red
    Blue/White---- amp. Turn on
    Blue---antenna turn on
    Orange—illumination
    Speakers wires are white;white/blk----green; green/blk---purple; purple/blk---gray; gray/blk. Now for your car I need to know the model
    Jan 01, 2010 | Car Audio & Video
    Need color code for radio harness
    Hello Mexicano1037,
    Here are the colors for the radio harness on your '91 Escort.
    1991 Ford Escort Radio Color Codes
    Battery Constant 12v+ Wire: Blue/Red
    Accessory Switched 12v+ Wire: Blue/Black
    Ground Wire: Black
    Illumination Wire: Red/Black
    Left Front Speaker (+): Violet
    Left Front Speaker (-): Blue/Orange
    Right Front Speaker(+): Blue/White
    Right Front Speaker(-): White
    Left Rear Speaker (+): White/Blue
    Left Rear Speaker (-): Red/Blue
    Right Rear Speaker (+): White/Green
    Right Rear Speaker (-): Blue
    Hope this helps.
    Apr 12, 2009 | Car Audio & Video
    Wiring on a RCA RJ-45 wall jack
    the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
    1 Blue --- Orange/White
    2 Orange --- Orange
    3 Black --- Green/White
    4 Red --- Blue
    5 Green --- Blue/White
    6 Yellow --- Green
    7 Brown --- Brown/White
    8 White --- Brown
    I'd still recommend a CAT5 wallplate with a CAT5 jack.
    Apr 11, 2009 | Computers & Internet
    RADIO INSTALLING
    there is a code for color!? ok, wait im searching...
    found it! here you go, hope it helps...
    Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
    Jun 19, 2008 | 2001 Chevrolet Tahoe
    Wiring a new radio in 1991 ford explorer
    1991 Ford Explorer XLT Radio and Speaker Wire Colors
    Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
    7 wire plug (I could see these wires immediately from the plug):
    Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
    Car Radio Ground Wire = Black
    Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
    Car Radio Dimmer Wire = Light Blue w/ Red Stripe
    Car Radio Illumination Wire = Orange w/ Black Stripe
    ?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
    Car Radio Amp Wire = Blue
    8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
    Right Front:
    White w/ Green Stripe (+)
    Brown (no stripe) (-)
    Right Rear:
    Purple w/ White Stripe (+)
    Light Blue (no stripe) (-)
    Left Front:
    Light Green (no stripe) (+)
    White w/ Orange Stripe (-)
    Left Rear:
    Light Blue w/ Black Stripe (+)
    Yellow (no stripe) (-)
    Speaker Wires (found at the individual speakers in the doors)
    Right Front:
    Green w/ Orange Stripe (-)
    Right Rear:
    Orange w/ Red Stripe (+)
    Black w/ White Stripe (-)
    Left Front:
    Orange w/ Green Stripe (+)
    Blue w/ White Stripe (-)
    Left Rear:
    Red w/ Green Stripe (+)
    Red w/ Blue Stripe (-)
    Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
    Feb 08, 2008 | JVC KD-G230 CD Player
    Hunter Fan Company 5/1/1 Programmable Thermostat Logo
    63 people viewed this question
    Top Hunter Dryers Experts
    Paul Bade
    Thomas Perkins
    Thomas Perkins
    Are you a Hunter Dryer Expert? Answer questions, earn points and help others
