Question about Hitachi 42HDT79 42 in. Plasma Television
I have A Hitachi 42In Plasma Tv model # 42HDT79 The blue light is blinking continuously and in the back of the set on 5 error code lights the third is lit green the 4th is lit orange screen is lit but no video or audio. Ithink it is probably the main board. I would just like to hear some iodeas or opinions. Also, none of the buttons on the side of the Tv work.The 2nd error code light will occasionally come on and when it comes on the blue power light will stop flashing but then it goes right back to blinking. When the light is not flashing the buttons on the side still do not work.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Main board is possible but power supply board should first be tested.
Posted on Dec 06, 2012
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 197 Answers
SOURCE: flashing blue light error code reset?
bad main pcb
Posted on Jun 07, 2009
SOURCE: Hitachi 50" Plasma (P50X01AU), power light comes on but no screen
Hope you already resolve it, if not, here what I went through 1. Try to get a service manual for your model ($10-18) from http://www.service-docs2.com or similar place. 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Posted on Jun 12, 2009
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Posted on Nov 13, 2009
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
WHY WON'T MY HITACHI PLASMA TV SHOW PICTURE OR SOUND? WHAT DOES THE BLUE LIGHT ON THE FRONT FLASHING 4 BLINKS MEAN?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 31, 2016 | Hitachi Televison & Video
Hitachi plasma tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
Hatachi 42in tv L42vco4u blue light flashing
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 17, 2015 | Televison & Video
Hitachi 50 in flat screen tv plasma blinking blue light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 17, 2013 | Hitachi Televison & Video
I have a Sony wega 42in tv and the tv keeps shutting off and the red light comes on
Self protection circuit will cause this---see if blinks are in a sequence---5 blinks, pause and 5 blinks etc---that will be a error code and you Can Google the model number to learn what the error is and what in general causes it.
Dec 08, 2012 | Sony Grand WEGA KF42SX200 42" TV
Hitachi Plasma tv model #P50H401 Picture went out, and I get 2 blinking blue lights. I downloaded the repair manual, and 2 blinking lights indicates a failure with the x-sus board. If this is the case, can...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 03, 2017 | Hitachi P50H401 50 in. Plasma HDTV
My Hitachi tv model p42h401a will not turn on. The "standby"light is not on either. I have checked the power supply and that is working.
Have you opened the actual TV and checked the power supply board inside? Because that is what it is. You need a new one.
May 09, 2011 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 42HDT79 42 in. Plasma Television Logo
385 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
