My 70 series just humms
I pulled the motor out and plugged the conectors in and pushed the lid switch down and it humms if i turn the motor shaft a couple of times the motor starts up
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 05, 2012
4 Suggested Answers
SOURCE: Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Posted on Feb 14, 2009
  • 3741 Answers
SOURCE: Kenmore 800 Series model: 11026842692 Will not rinse or spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 05, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
The button the drum stops.When I push the start button the drum starts turning but when I release
it's the start switch on the motor . it might be bad or the spinning weights on the motor shaft may be gummed up with lint
you would have to take out the motor and check out the spinning shaft weights to make sure there clean and move to disconnect the switch when the motor starts.
my guess when you get in there you will find lint ,string and all such stuff all wound up around the shaft keeping the switch from working
Feb 02, 2016 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
My kenmore washer series70 motor humms
yes there is a capacitor on most washing machine motors on a kenmore series 70 it should be on the right front panel upright leg
Dec 06, 2012 | Washing Machines
My kenmore 70 series washer quit agitating and spinning today. what could it be?
i think you will find the belt at the bottom has broken or come of here are the directions to replaced / re fit it
best of luck
merry christmas
  • Unplug the power cord of the Kenmore 70 series washer from the electrical outlet before attempting to replace the drive belt. Remove the end caps from the control console by pushing in on the center of the caps with your thumbs and pulling the caps forward.
  • 2 Unfasten the screws on the front of the control console with a screwdriver and set the screws aside. Flip the control console back so it is resting against the rear hinges.
  • 3 Locate the two-pronged electrical plug on the top of the washer near the back and unfasten it by pulling the plug straight up by hand. Remove the metal clips on the top of the washer, prying them up with a screwdriver and setting them out of the way.
  • 4 Lift the washer cabinet off the base and set it aside. Locate the motor at the base of the cabinet near the front and unhook the springs from the motor carriage with a pair of pliers.
  • 5 Unbolt the motor from the motor carriage, using a socket wrench to unfasten the bolts. Unplug the electrical wiring harness from the motor by hand.
  • 6 Lift the motor off the motor carriage and take the drive belt off the motor and transmission pulleys, discarding the belt. Place the new drive belt around the transmission and motor pulleys.
  • 7 Plug the electrical wiring harness into the motor by hand and secure the motor to the motor carriage with the bolts. Attach the springs to the motor carriage by hand.
  • 8 Place the washer cabinet back over the base and secure it with the metal clips on the top lid. Connect the two-pronged electrical plug to the top lid of the washer by hand.
  • 9 Flip the control console back down over the washer lid and secure the console with screws in the front. Place the caps back over the ends of the control console by hand.
  • 10 Plug the Kenmore 70 series washer into the electricity supply and test wash.
  • have fun
    Dec 08, 2010 | Kenmore Washing Machines
    I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
    Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
    Sep 06, 2010 | Kenmore Dryers
    The motor just humms loudly when I try to start it. If I give it a push it will start spinning, but boggs down if I put any food through it
    Take the bottom plate off to expose the motor, drive belt, and pulleys (pull the power plug for this). Remove the drive belt and turn the motor shaft by hand--does it seem to turn freely? Do the same with the driven pulley--it should turn freely also. The pulleys and belt are likely cog-type and not prone to slippage. If either pulley shaft is excessively hard to turn, then investigate the reason,and replace parts if necessary. With the belt off, the motor should accelerate almost instantly. If relatively slowly, the motor may need to be replaced.
    Jan 31, 2010 | Kenmore KFP-70 Food Processor
    I have a Kenmore 70 Series Washer. The lid switch
    Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
    Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
    Washer is making a grinding noise. It want spin or agitate.
    sounds like ur shaft is stripped motors about 100 bucks ur call prob better get a new one
    Dec 31, 2008 | Kenmore 22422 Top Load Washer
    i have a kenmore 70 series washer model 10020722990
    it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
    Sep 05, 2006 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
