Question about Samsung HL-S5087W DLP TV
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Posted on Dec 05, 2012
  • Susan B Dec 09, 2012
    I believe it is a Samsung bulb, not sure what seated means but it was installed properly ( and rechecked) and there is sound. It is just the picture that goes off. Someone suggested it may be the DMD board, but at this rate too costly to replace. I have already changed the bulb and the color wheel once and the tv is only 6 years old.
    sorry- replaced the bulb twice and the color wheel once.
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
  • 49 Answers
SOURCE: Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Posted on Jan 24, 2009
  • 98 Answers
SOURCE: Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Posted on Mar 03, 2009
nicknovikov
  • 100 Answers
SOURCE: I have a Samsung 43in DLP TV. Stays on for 5
check power board for looseconnections.
Posted on Jul 09, 2009
  • 336 Answers
SOURCE: TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Posted on Oct 06, 2009
I have the samsung syncmaster t220. had it for about 2 years and just recently it has started going blank. i can't turn it back on any other way than to reboot the pc. there is no warning that it's going...
Since it works for 2 hours it may not be cooling fan problem, neither RAM. Not at all the screen because it's okay after reboot. Most probably the Power circuit could be erratic.
Sep 15, 2017 | Samsung T220 22" Widescreen LCD Monitor
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung FPT5084 Plasma TV and it keeps shutting off
It could be the power PCB, but it is hard to say over the internet.
I am looking for one with a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks
yrk2.7t AT (replace with @ symbol) gmail.com
Jul 29, 2009 | Samsung FPT5084 50 in. Plasma HDTV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HL-P6163W DLP sometimes turns on with NO PICTURE
sounds like the dmv pcb bpard cost 597.70 and about a 250 core charge from andrews electronics.
or you can look ay the price at partsstore dot com.
regards,
daniel.
Jan 09, 2009 | Samsung HLP6163W 61" Rear Projection...
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Samsung 1080p turns itself off
Probably a bad Inverter board. I have a Dell 32" LCD TV but it has a Samsung Panel inside, found a burnt transformer on the inverter board, Still trying to find a replacement.
My TV comes on for a second then goes black, power still shows on but no picture. 1.5 years old
If you are not a tech person, take it in for service.
Dec 27, 2007 | Samsung HL-R5678W 56" Television
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Samsung HL-S5087W DLP TV Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
