Question about Coleman Intertherm Nordyne Miller Furnace Control Board 904531
I have an intertherm furnace.I am having a problem where the furnace will not stay running.The furnace starts normally but starts to rumble and sputter after about 20 seconds and then cuts off.I'v
  • Amanda Drew
    Amanda Drew Oct 12, 2017
    That's weird that your furnace will turn on for around 20 seconds then shut off. My furnace has also been acting a little off. It stays on, but it doesn't actually pump out any heat. We have pretty cold winters where I live, so I really need my heater. I think that the both of us should probably find professional heating repair to look at our furnaces.http://www.northwestheating.biz
  • Coleman Master
  • 6,674 Answers
Have you had chimney/stack checked for any obstructions, so air can flow through and out properly. Also have gas pressure checked and burner cleaned.
Posted on Jan 28, 2013
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
Intertherm propane furnace will not stay on
your machine is missing the oxygen check your ventilation,
1. try to turn it for 1 minute with leaving the door open.
Mar 24, 2014 | Intertherm Heating & Cooling
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm Furnace Will not stay on
Your furnace is likely getting too hot check your filter. make sure the fan is running. if you have weak air flow you may have a blocked heat transfer coil. you should have your heating and cooling system serviced yearly by a qualified company to inspect and test equipment.
Jan 04, 2009 | Intertherm Heating & Cooling
Furnace won't stay on
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Dec 21, 2008 | Intertherm P3RA-048K Air Conditioner
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Coleman Intertherm Nordyne Miller Furnace Control Board 904531 Logo
533 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
