Question about Genius Twin Wheel F1
PADDEL SHIFT ANDBUTTONS DONT WORK
ONLY GAS AND BREAK WORKS AND STEARING
My daughter has a 1992 full size bronco. One day while trying to shift, the on the column shifter broke? A friend of hers fix it to where she can shift it by pulling on and pushing on the cable that was...
These are dealer or salvage yard parts.The dealer will be able to pull up a scematic on the computer that you can point out what you need.A salvage yard may be willing to sell parts off a bad column but i would be suprised if anyone has this old of a part laying around.Parts stores will not be able to help you so knowing the name of the different parts is not really important.Usually what happens is either the bolts that hold the shift cable bracket to the shift shaft back out and break the shift shaft or the bushings that hold the shift shaft in place wear out and get the shaft in a bind and break it.I would be suprised the bracket is broke since it is made of steel.Most likely the two #30 torx bolts that hold the bracket to the shaft are loose or missing or the shaft is broken.I bet the dealer has the parts you need in stock.If you have to replace shaft be sure and replace bushibgs with new updated ones even if they look ok.You dont need to diassemble stearing column to do the work.Remove panel underneath and remove 4 bolts holding column and it will drop down so you can work on shift shaft.If you need to remove ignition switch just place key in the acc position and press button on bottom of switch housing and the lock cylinder will come right out.Good luck and please vote.
Feb 13, 2011 | 1992 Ford Bronco
Hi i have a 99 fiat punto the flashing unit only works every now and again i want to replace it is it hard to do i tuck off the cover under the stearing wheel i can see the unit but dont want to break...
the flasher is simple to change, it pulgs in and pulls out to replace, the best way is to do it when signals work this way its easy to find under the dash, just listen for the clicking noise to pinpoint it, hope this helps, heres a picture of it, its gonna be one of these,8e13102.jpg591d400.jpg
Oct 27, 2010 | Fiat 500 Cars & Trucks
Break pedal sometimes vibrates when the breaks are applied. Also some sort of knocking sound coming from the hood when slowing down at low speeds
They have ABS and when you press the pedal hard the pedal vibrates. its the computer doing a pumping action for your. It grabs and releases the breaks so they dont lock up and it allowys you to stear your vehicles while the brakes are firmly pressed.
Jun 25, 2010 | 1995 Cadillac Seville
2005 nissan altima HELP
SOUND LIKE THE BRAKE LIGHT SWITCH IS BAD.
May 08, 2010 | 2005 Nissan Altima
My 2005 Chevy Impala's power stearing problem?
From the sounds of it, that pothole messed up your steering. Something is binding in the steering train, could be a damaged tie rod end, one of the other steering joints, or even the rack and pinion steering itsself. When it's binding, the power steering pump has to work too hard, slowing the engine down, making your lights dim because it's also slowing the alternator(on the same belt drive) and furthering your steering problem. You need to get it checked out immediately before something breaks and gets you into an accident. Remember, if steering linkage breaks, you have NO control of your vehicle, and it doesn't care if you're driving 70 mph on the highway.
Dec 09, 2009 | 2005 Chevrolet Impala
I have a 1990 f150. we dont get any power to the
well you need to check the fuel pump relay first there is no reset switch
Aug 20, 2009 | 1993 Ford Explorer Limited
Gearshift lock
please try giggling the key a bit when pressing break pedal and also wiggle steering wheel and see what happens. does it go in eventually ? and if so what did you do to get it into gear i'll be waiting to hear from you good luck ps sounds like it could be a poorly adjusted park switch or a bad ignition switch not unblocking the safety shift lock.
Jun 30, 2008 | 1999 Ford Taurus
Paddel on right side
Have you tried reinstalling the latest software from Logitech ...I have a Momo wheel and a reinstall has fixed a couple of issues for me ...
Jun 03, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Need A Replacement Paddle
I have 2 breadmachines 1- K6745 & 1-welbilt ABM2H60 model. The paddel for the latter should work in the k6745. The female shaft of paddel is a little short but should do the trick, I think. Both machines have the normal type loaf pan, and the paddel did fit onto the shaft, so maybe looking at another machine w/ same style of pan will work also.
I really enjoy my K6745 but in a move I lost my manual could you e-mail a copy to me?
Aug 27, 2007 | Regal Ware K6745S Kitchen Pro Bread Maker
Genius Twin Wheel F1 Logo
161 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
