Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Tv turns on then right back off again
I have a magnavox 51mp6100d/37 projection tv and when i plug it in and turn it on it stays on for about 10 seconds then turns back off and the power button flashes
  • 3 more comments
  • jarhead1229 Jan 12, 2009
    how do I find the power supply?
    how do i tell what the power supply is
    I hate to sound stupid but is the power block about 1 inch by 1 1/2 inches and has 4 pins going through the circuit board with copper wire coils?
    thank you you have helped alot but if this doesn't fix my problem do you have any suggestions of where to go next?
    the expert was very friendly and helpfull hopfully his advice solves my problem
    President:
  • 1,990 Answers
Welcome to Fixya! This is your Power supply. You can replace this or take it to an Authorized Repair shop.
Posted on Jan 12, 2009
  • 3 more comments
  • Travis Humphries
    Travis Humphries Jan 12, 2009
    I do Believe that Radio Shack carries a Power Supply that will be Ok to use in place of your old one. Just take the Old one in and Match it.
  • Travis Humphries
    It is on the Inside where the Power Cord goes into the TV it will run right into the Power supply Block. No guess work. Should be a simple repair with a Soldering Iron and a little TLC!
  • Travis Humphries
    Yes, If the Cord winds up in that location. There are Hundreds of Variations and Sizes. No you don't Sound Stupid! Remember though- The rule of thumb with Repair is -- If you are not Comfortable with the Repair, Let an Expert Repair it! I have actually done this before!
  • Travis Humphries
    Ok- My diagrams of other sets Displays this as the Power Coil. As described Obove.
  • Travis Humphries
    This should fix your Problem. However, If it happens to be the board that is going bad I would definately get it to an Authorized Repair Center. No Problem on the Help! I do this for Extra Money for my "Toys" LOL Not a Lot of Money But, It HELPS!!!!!!!
Ihave a 52" Magnavox rear projection TV. Model no.
You need a convergence kit available at tvrepairkits.com
Jan 04, 2011 | Philips Televison & Video
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp6100d/37 power light flashes and
you can get replacement boards from www.tvrepairworld.com you can call or send them a email they respond quickly.
Apr 15, 2010 | Televison & Video
I contacted you today about the Magnavox HDTV 51MP6100D/37 that had a problem with the remote not working and the sound on TV not working I took the batteries out and put them back in and the remote is now...
My thoughts is to look through the menus. You may have the option to turn the TVs speakers off and use the Variable Audio outputs. Many use this feature to connect their audio to a surround sound system.
Just a thought.
Nov 21, 2009 | Televison & Video
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
We have a Magnavox 51MP6100D/37 tv that doesn't have a manual,
http://www.retrevo.com/support/Philips-51MP6100D%2F37B-TVs-manual/id/278dj091/t/2/
Nov 25, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
