Question about Parker Grill
Where can I buy a replacement regulator for my Parker gas grill?
Plastic knob on regulator is cracked causing gas leak where it attaches to LP tank. Needs replacement. Can I get a regulator/hose?
Hi kimandjimm...
You can use any generic hose and regulator assembly for your grill.
You can buy it online at: http://www.appliancefactoryparts.com/gasgrillparts/brands/charbroil/charbroil-plumbing-valves.html
You can buy them at HomeDepot,Lowes,Ace Hardware,etc. Look in the grill section.
Please take time to rate me
Sep 07, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
I've just moved to the US and need a new regulator for my Weber Summit E-450. Is there a specific regulator for this model?
Hi imclaughlin...
No the regulator is not "grill specfic"...you can normally go to Home Depot, Loews, WalMart and buy the new regulator with new hose/s already attached for a decent price and replace the faulty one on your grill.
Aug 15, 2011 | Weber Summit E-450 Gas Grill
Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
May 15, 2010 | Kenmore Grilling
Something chewed on the regulator hose I need to replace it can I just replace the hose? Do I need to buy a new regulator if only the hose is chewed up?
Generally when you buy a new hose it comes as one unit with the regulator built in. Remove it, and take it to the store where you are going to buy the replacement. Home Depot and Lowes carry these replacement hoses.
Jun 16, 2009 | Char-Broil 7000 Quick Set Gas Grill
Wont work in a any breeze- flame keeps going out.
Parker actually helped me solve the problem, but indirectly. Be certain that both plate holes are aligned. I had taken mine out to clean and was unaware that it mattered how reinserted. Give it a try.
Feb 01, 2009 | Parker Grill
Lack of parts and support
Just don't buy another, so far I cannot get A REPLY CONCERNING ANYTHING! Nice grill, would love to buy a replacement burner tube and bottom plate. Too bad!
Nov 17, 2008 | Parker Grill
Sears gas grill
If it was me I would return it. You did the right thing by testing it on another grill. You should not have to accept a new grill that is not working properly.
Loringh
Nov 04, 2008 | Grilling
Don't buy Parker grills.
This person complains but provides no issues or facts. Sounds like a nut case.
May 21, 2008 | Parker Grill
Parker Grill Logo
89 people viewed this question
Top Parker Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Parker Grilling Expert? Answer questions, earn points and help others
