Question about Kyocera Finecam Cameras
Battery cover won't stay closed. Where can I get a new one?
Have tried taping it, but because it is sort of spring loaded it keeps popping out. Camera will not work if cover is ajar.
t00nz
  • 4738 Answers
SOURCE: Lens cover jamming
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
SOURCE: fujifilm s5000 I want to buy a new battery door. Is that possible?
I have the same problem and after many different contraptions to try to keep it closed I simply used a ponytail holder. Just a simple brown hair elastic. (a large one) It has worked well for over a year now.
Posted on Feb 19, 2009
  • 9 Answers
SOURCE: Fuji S5000 camera problem....The battery door will
Also see post:
http://www.fixya.com/support/t1747423-fuji_finepix_s5000_battery_door
OZwombat suggests a aluminum bar holding the battery door shut, attached to the case with a screw in the tripod connector
604foxtrot replaced half the camera case with that of a used (broken) camera
Elastics, tape etc does not work
Posted on Apr 07, 2010
welcomejee
  • 10594 Answers
SOURCE: I dropped my Sony DSC-W1/W12
Yes, you can get new battery holder that comes with cover, part number is as follows:
175648311.... HOLDER, BATTERY (WITH TERMINAL Silver)
DSC-W1 Camera will take apart to replace battery compartment.
Hope these info will help you.
Thanks.
Posted on Sep 27, 2010
  • 3287 Answers
SOURCE: I'm trying to disassemble an
I found someone with the exact same problem, and this is how they made the repair:
My Olympus SP-570uz also has a broken flash spring. I found that small a coil spring approximately 3/16" max diameter and approximately 7/8" to 1" long can be inserted in the flash cavity when it is open - place on the right side (looking at the front of the camera) in the area that does not interfere with the small latch that locks the flash in the down position. The coil spring will need to compress enough to allow the flash to close completely.
I realize that this is not how to open the camera to to make the repair the way Olympus would do it, but it may be worth trying before attempting open it without forcing it or while waiting for dis-assembly instructions.
Posted on Aug 16, 2011
My battery door cover doesn't stay closedbattery door
Push it closed with thumb .. hold closed..then slide forward
Nov 19, 2013 | Nikon Coolpix L22 L-22 Black Digital...
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Printer keep saying cover is open and cant find
====.> continued from an earlier answer that seemed to close up too soon, before I finished typing my response.
... and the cover appears to the printer to be open. If you can clean this photo-ectric sensror, it will tell the printer that the cover is actually closed, as it should, and the printer will return to printing as it should do.
Clean all photoelectronic sensors, to ensure that they are all going to respond as they should, and your printer will then work fine.
-a.
Dec 06, 2009 | Dell Office Equipment & Supplies
Battery and memory card compartment cover wont stay closed
ours does the same thing, i couldn't figur out a way to keep it ****, so i just taped it.
Jul 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Door does not stay closed
The latch that holds the door has snapped. time to take it apart. The spring may have come off or you could need a new unit.
Mar 25, 2008 | Sony PlayStation 2 (PS2) Console
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Cameras Logo
19 people viewed this question
Top Kyocera Cameras Experts
Iqbal Husain
Iqbal Husain
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
