Slide projector Novamat 515 is broken. Want to look inside and fix it but I can't remove the lid. After unscrewing the bottom ans side screws the lid remains stuck and does not come off. Anyone kmows how to remove it?
  • Alessandro Dec 11, 2012
    thank andrea_pappa, unfortunately my projector is novamat 515 af-t: no carousel, but horizontal slide car. fixya put the wrong picture ... can anyone help?
    this is the right picture
    Genius:
  • 1,669 Answers
Try moving the vent cover that is over the actual bulb! I believe it slides off, but am not sure. The bulb is directly beneath it. When installing a new bulb, DO NOT HANDLE IT WITH YOUR BARE HANDS. Oil from your fingers will shorten the life of the new bulb!
Posted on Dec 31, 2012
3 Suggested Answers
  • 48 Answers
SOURCE: I have a braun Novamat
Apparently you are not using glass slide mounts and your slide is popping in and out of focus. If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Posted on Sep 15, 2011
SOURCE: My Kodak Carousel 650H has a stuck slide and the
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Posted on Jul 31, 2011
Krups 8278. How to take apart
If it is EA8278 then tank out, bottom tray out, debris container on side out, drawer above it out. Unscrew 1 or 2 screws inside beans container, remove adjustment knob (clicks up and off) remove beans container. Undo two outer screws under front top flap and one screw at center back was hidden by beans container. The oblong full size bezel at the front of the machine clicks upwards to click out of its clips. Lift lid at the front and wriggle it about forcefully to unclip the rear catches. Undo 2 screws one each side at bottom that were exposed by front bezel removal and 2 screws exposed by tank removal. Rear and sides are one piece and slide back for removal. That's it, you're in.
Feb 04, 2017 | Krups Coffee Makers & Espresso Machines
How do I open up a Rank Aldis 2000 Slide Projector to replace a bulb and free a jammed slide?
1. Prepare to turn projector upside down.
2. Unscrew & remove focusing lens.
3. Turn projector upside down & look from the base face of the projector towards the lens aperture - for a slot just under the lid lip. There is a black tab which can be slid with a screwdriver away from the slide path.
4. There's a similar slot at the back under the lid lip and the end of the row of vent holes.
5. After sliding these, the lid is loose - so while holding the lid in place, turn the projector back over onto its feet.
6. The lid now simply lifts off - first at the slides side, hinging away and then off.
Aug 27, 2016 | Office Equipment & Supplies
I have a braun Novamat 515 AF-m slide monitor. when the first slide is shonw you have to manually focus. Thereafter the auy=to focus takes over for remaining slides. problem the auto focus does now not...
Sep 07, 2011 | Office Equipment & Supplies
Hi, my pushed slide arm its broken, were can i found the pice. thank you
Sep 01, 2011 | Braun Novamat 130 AF Slide Projector
Where can I get magazines for ther Novamat 130 AF large
Most camera stores sell Gepe Universal Straight Trays and some also have the LKM trays. You can also order Braun CS trays in the USA from: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Aug 03, 2011 | Braun Novamat 130 AF Slide Projector
The reverse forward feature doesn't work
To advance the slides forward just tap the advance button. To revers it hold the advance button down. If that doesn't do it it will need service.
Nov 12, 2010 | Braun Novamat 330 Slide Projector
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    Kodak ektagraphic AF 1 reverse does not work - anything I can do?
    If there are no broken components of the slide change mechanism and it is only an adjustment problem, do the following:
    1. Remove the bottom cover
    2. At the front of the projector (near the elevation wheel) you will find (2) 1/4" head screws going through black rubber grommets. Loosen the screw slightly.
    3. Next to the screws you will see a cutout in 2 pieces of metal that when looked at together, resemble a diamond shape.
    4. With the projector on in FAN mode only (NO LAMP!), simultaneously press the reverse button on the side of the projector and with a flat-blade screwdriver inserted into the diamond-shaped slot, twist gently to move the plate the 2 screws go through up or down until you get cycling in reverse. If you go too far you will get buzzing, which will indicate that the solenoid plunger is bottomed out in the solenoid coil. Once you get acceptable reverse cycle, tighten the 2 screws gently and turn the projector right-side up. Verify the correct action in both forward & reverse cycle. Adjust further if necessary. If OK, tighten the 2 screws and re-install the bottom cover. You're done!
    Apr 24, 2010 | Kodak Office Equipment & Supplies
    Getting projector open to replace color wheel
    You need to open the top lid of the DVD player and you'll notice 2 more screws. Those need to be taken out. Then the lid will lift off the base. You'll then need to undo a couple of the wires to completely remove the lid. After this, you will have to remove the silver lid inside to gain access to the color wheel. It's pretty simple. Assembly is reverse.
    Oct 15, 2008 | Optoma MovieTime DV10 Multimedia Projector
    302 people viewed this question
    k24674
    jasbo
    jasbo
