Question about Maytag Refrigerators
MAYTAG SIDE BY SIDE MSD2650KEU
Entire unit is not able to get cold. Freezer is not freezing and refrigerator is not cool. Unit is plugged in and running. This seemed to have happened overnight. The unit is about 10 years old. Should I replace it or is it worth it to find a repairman to fix it?
  • 3 more comments
  • Geanine Jamison Dec 06, 2012
    The compressor doesn't seem to be doing anything. I removed the cover last night and cleaned it out. I cleaned out the freezer and fridge. We left it unplugged all night. I plugged it in before I left this morning. Not sure if we'll have any change. I think the compressor is finished.
  • Richard Roth
    Richard Roth Dec 06, 2012
    I don't think so. Pull the relay off of the compressor and shake it. If it rattles, it is bad and will need to be replaced. Here is the relay to order.http://bit.ly/TVEarX Be sure you have the unit unplugged first!
  • Richard Roth
    Look at this video.
    I removed the relay and it was melted where it was connected to the compressor. Bad?
  • Richard Roth
    Oh yea! It's bad! Here is the relay kit to order.http://bit.ly/TVEarX This will get you running again. This refrigerator compressor starting device includes the relay, overload with start capacitor. Keep me posted!
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check to see if the compressor is running and hot. Post back your results.
Posted on Dec 05, 2012
  • 3 Answers
SOURCE: Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Posted on Aug 20, 2007
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
SOURCE: GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Posted on Jun 24, 2009
woodchuck789
  • 4059 Answers
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Why is my haier refridger not getting cold
There are alot of things that can cause no cooling...
a stuck tstat, will cause it to freeze up(electronic control)
a broken defrost timer will cause ice build up from no defrosting
out, or low on freon charge
inefficient compressor
door gaskets leaking
light switch not cutting off the light inside the cooling or freezing compartment
a bad fan motor(door) switch
I dont know how your unit works, but most only have one evaporator in entire unit..and its in the freezer compartment, and the cooling side gets it (coldnest) from the freezer compartment..with a door flap that alows cold air from the freezer to enter the cooler side.
Hope this helps..
Jun 04, 2014 | Samsung RS2630SH Side by Side Refrigerator
Maytag Performa - PTB1953DR - FRIDGE IS NOT STAYING COLD, WE HAVE IT UP THE ENTIRE WAY AND IT IS COOL BUT NOT COLD. FREEZER IS STILL FREEZING BUT NOT WHAT IT SHOULD BE, ICE CREAM IS FROZEN BUT NOT HARD.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Freezer keeps freezing over then the entire unit stops working, what is this??
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 15, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
Fridge not cooling, freezer not freezing, buzzing sound
with any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Oct 02, 2009 | Maytag MTF2155GRW Top Freezer Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Maytag refridgerator not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Freezer not freezing
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
Dec 11, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Refrigerators Logo
75 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
