Question about Kenmore 53642 / 53644 Side by Side Refrigerator
ICE MAKER NOT GETTING ENOUGH WATER - Kenmore 53642 / 53644 Side by Side Refrigerator
  • 22 Answers
I had this problem on a refrigerator with an automatic icemaker. Where the water line attaches to the source pipe is a Self-Piercing Tap valve (sometimes called a vampire tap, or a saddle valve). The hole that this device made to feed the freezer was not allowing sufficient flow during the fill cycle of the icemaker.
I had to turn off my water and trace the water line that feeds my refrigerator back to the water source. I then disassembled the valve, enlarged the hole in the water pipe slightly, and reassembled. Turn the water back on and check for leaks. The trick is to enlarge the hole just enough to deliver the need water, but keep it small enough so the saddle valve can seal the junction.
Posted on Jan 12, 2009
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
SOURCE: no water to ice maker
We had a problem with ice maker not making ice. After alot of concern it turned out we just needed to replace the filter.
Posted on Aug 07, 2008
SOURCE: b195 ice maker not making ice
the solenoid might have packed it in
Posted on Oct 27, 2008
Why is my ice maker is not making ice
Sounds like its not getting enough water to the ice maker tray during each cycle. Possible restricted water fill line, plugged water filter or low water pressure to the ice maker.
Oct 08, 2014 | Frigidaire Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Got a new water valve for the refrigerator but still no water getting to the ice maker
make sure arm is down so ice maker can cycle. when it gets cold enough it should cycle through.
May 26, 2012 | Refrigerators
Wsf26c2exf ice maker not making enough ice.
Jul 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our ice maker has stopped making ice. I've replaced the water filter (we are still getting water through the door), the "arm" is in the down position, and the temperature is cold enough. Any...
If the cube slots are empty try filling with tap water and allow to freeze while arm is down. If cubes drop and the ice maker does not refill with water then the dual water control valve=> 67005154 Dual Water Control Valve Another possibility is the ice maker thermostat pictured here=> MZD2669KES Ice Maker Parts Breakdown item 13 in photo. If the test fails then it is sometimes better to buy the complete ice maker=> 7824706Q Ice maker Module
Jan 26, 2011 | Maytag MZD2669KES Stainless Steel Side by...
My ice maker is not getting water. The water despenser is o.k.---I did remove the water filter.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Nov 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
How to fix automatic ice maker thats not getting
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
Sep 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
The units not getting enough water pressure to keep the water flowing fast enough not to flash freeze in the fill tube. You will have to check the water supply valve on the plumbing and the back of the unit to see witch on needs cleaned out or replaced.
Apr 18, 2008 | Refrigerators
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
