Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have forgeted my windows xp Login Password, How I can remove my password without any loss. please send me solotion.
    Novelist:
  • 84 Answers
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Posted on May 10, 2009
  • getbackwindo May 10, 2009
  • 155 Answers
Open the side panel of your tower and remove the lithium battery for around 20 minutes. Put it back and reboot pc. This should remove password.
Alternatively, press F2 on startup until you come to an option screen. Start in safe mode and you should see a hidden Administrator Account where you can remove your password from.
Posted on May 04, 2009
    Guru:
  • 108 Answers
With the rapid spread of the Internet, people's personal info on PC has been badly threatened. So, as a PC user, it is necessary to hand some common senses like setting OS password and revoking login info so on. Followings are some common senses about how to setting login info and how to revoke login info when you have forgot your user ID or password.
Setting password:If you have the user password to login to the local windows xp or nt computer, you computer will be protected by the login info which is only known by you, so that any other can not login to you PC without your promise. Well, then, how to set a login account? There are just several steps:
Step one: Open the "Control Panel"
Step two: Click the "User Account "
Step three: Click set up a new account on the User Account windows and then input a user name that you must remember it. Click "next" and select "Computer Administrator" option, then set up a account. In this way, you have a user name. From step four, you start to set up a password.
Step four: Following above steps, clicking "changing Account " and "set up password", then fill out the form as listed. Click "Create Password".
Thus, you have a personal login ID and Password, any one has no right to login to your computer with out this info.
A login account is not absolutely safe. Sometimes, you may reveal your account info or your PC is cracked by hacker. So, It is essential for you to change the account info now and then. If you have known how to set a account, it will be ease for you to change account info. Likewise, just a few steps, you can change or delete login info.
Revoking password: Besides, lots of people may forget their login info which possibility can't be ruled out. For most of people, like freshman, may reinstall the OS so that all of the original files would be lost and all our works may go up in smoke.
In fact, there are some convenience ways to help us to be far from that nightmare, as long as you paste "windows password", "xp password", "administrator password", "vista password", "windows xp password", "forgot windows password", "windows administrator password", "windows password recovery", "windows password reset", "windows password unlocker", ect to google, there would be many related results. One of the most reliable way is to take use of windows password unlocker which is a current windows tool for empty or reset windows password for PC users even computer freshman. With windows password unlocker, just a few steps, you can re-login your PC without any data loss.
Step1. Download Windows Password Unlocker 4.0. Click here to download Windows Password Unlocker 4.0 and save it to your hard disk. Take note of what folder you saved the file in.
Step2. Burn the downloaded ISO file onto a CD. * To burn your CD, you'll need a blank CD-R . * If you are familiar with burning .iso image files you may use any software you already have such as Nero, Sonic, Roxio etc. If you need burning software we provide one of the best solutions on the market called BurnCDCC. Click Here To Download.
Here is the process using BurnCDCC Step-By-Step:.
Step 3. Put in your newly created CD and remove your Windows password. * (1) Insert newly created CD in your CD drive and reboot your computer. When the CD boots, you'll see Windows Password Unlocker 4.0 initializing (see screen shot below). If so, you can continue to the next step. If the computer still boots into Windows, it's necessary to change BIOS boot sequence to make it boot from the CD. You can find more info about this on our BIOS page HERE..
Windows Password Unlocker 4.0 boot screen
* (2). Select the user account you want to reset
I have forgeted my windows xp Login Password, How - 2.jpg Click the 'Reset' button to process.
* (5). In the end, a message box appears as below, indicating Windows Password Unlocker has successfully reset the password.
1. Double click BurnCDCC.I have forgeted my windows xp Login Password, How - burn_open.jpg.
I have forgeted my windows xp Login Password, How - burn_start.jpg Browse to locate the ISO file on your computer, right-click the file name, and then click Open to go to next step. burn_open.jpg
3. Return to the main window, and click Start button to continue.
Posted on Apr 29, 2009
  • zpowx2 Apr 29, 2009
    * (3) Click the 'Reset' button to process.
    * (4) Click 'Yes' to confirm your action. Or, click 'No' to undo your selection.
    1. Double click BurnCDCC.exe to run it.
    2. Then, click Browse to locate the ISO file on your computer, right-click the file name, and then click Open to go to next step.
  • 258 Answers
2 Suggested Answers
  • 2976 Answers
SOURCE: I have forgeted my windows xp Login Password, How I can
Remove it from the administrator side.
Posted on Jan 12, 2009
How do i log on without a password
If this is your computer?
Well, if so, you can remove admin password with the methods below.
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
Step1: Download Windows Password Reset and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows password on the operation interface and logon PC without password.
Can it work for you?
Jun 13, 2012 | Compaq Computers & Internet
How to find Windows XP password out
Yes, you are right, you can use Windows Password Key to reset your password.Windows Password Key Standard can help you bypass your Windows password and successfully login to computer again without suffering from anyrisk of data loss.
Solution:How to Find Windows XP Password Out? ' Reset Windows Password ' Administrator Password Recovery
Jun 12, 2012 | Acer Aspire One AOD255-2333 Home Netbook
I lost my password for acer4220
To reset it with Windows Password Seeker, once the useful software helped me get back into my windows successfully.
Feb 28, 2011 | Computers & Internet
I lost my Computer's administrator password, is there any solution without reinstalling windows?
Hi, manav.
Yes, there is a way to access your locked computer without re-installing OS. Try using this password recovery software tool as it helps to reset your lost Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Should help you get rid of your problem. Regards.
Aug 27, 2009 | Microsoft Windows XP Professional SP2
Bought a used pc, do not have password for windows log-on. cannot get to bios, no boot up cd. what now?
Most XP machines have a built in administrator account that normally does not have a password.
You can try pressing F8 before Windows starts up to go into the XP bootup menu.
Choose Safe mode
Once into safe mode you should either see an 'Administrator' account listed, or just type in Administrator and do not type a password. If that works, go to Start-->Control Panel-->User Accounts. From there you can create a new user account for you to use with administrative privileges.
If that doesn't work, try downloading a password reset utility, such as the one at http://home.eunet.no/~pnordahl/ntpasswd/
Hope this helps
Jul 03, 2009 | Microsoft Windows XP Professional With...
I have forgeted my windows xp Login Password, How I can remove my password without any loss. please send me solotion at mazharpg@yahoo.com
Start up in safe mode go to control panel user accounts go on as administtrator then you should be able to remove user accounts and passwords then restart.
This should solve the problem.
Jan 12, 2009 | Microsoft Windows XP Professional
Unlock the windows password
I have a good way to remove your laptop password, you can download a file which called Windows Password Seeker. And remove and reset windows password instantly.
Jan 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
May 07, 2008 | Dell Inspiron 6400 Notebook
I have forgot my passwords
can remember my password and can't change use another SIM from the same network.
Apr 15, 2008 | Sagem my401x Cellular Phone
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
213 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
