Question about Dynex 32 in. LCD Flat-Panel HDTV
On off switch keeps going on and off on its own
    Top Expert:
  • Dynex Master
  • 14,553 Answers
A thought occurs to me: if the button on the outside of the set is the issue the remote will have no effect on trying to turn on/off.
Beneath or behind that button is a tiny push switch and they do go bad in exactly this way--engaging when not touched.
Only way is to get at that tiny switch and remove it to see if issue clears up or not.
Posted on Dec 06, 2012
What is the wiring sequence for the ignition switch on a John Deere CR125 ride on mower
Go on BING images, put in John Deere Ignition switch diagram and all sorts pop up. See if that helps. Most are the basic switch setup. Keep a copy for the future.
Nov 15, 2014 | Garden
Inside chime keeps going
POSSIBLY THE BUTTON WHERE THE DOOR HINGE IS IS NOT OPERABLE IF YOU CAN JUMP THE SWITCH WITH OTHER WIRES AND IT GOES OFF IT IS PROBABLY A FAULTY SWITCH
Mar 25, 2014 | 2005 Ford F-150
Alarm goes off for no reason
It can be any of the car door not got properly locked or the door is locked but the switch is not sensing the door locked.Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.And last thing alarm connections needs to be inspected.Its getting short somewhere in between.
There are few helplinks with solutions,to troubleshoot these types of problems.I suggest going through these links.
Click the link below:------Volvo car alarm keeps going off for no reason http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
------------------ Alarm keeps going OFF http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
--------------2009 Toyota Camry: Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
----------------Ford Pickup Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
------------Mitsubishi Diamante: Factory Security Alarm will not go Off http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
------------Toyota Avalon Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------These details will help.Thanks.
Nov 24, 2012 | 2005 Lexus ES330
Driver door ajar alarm keeps going on and off as I am driving and the door locks keep clicking on and off. This only happened occasionally, I sprayed WD-40 in lock area and it stopped for a few weeks. Now,...
This sounds like a bad door switch,if you replace the switch i think it will solve all these problems,the switch is locted on the latch asm,remove the door panel,mark and remove the linkage,then unplug connectors,then remove screws holding latch,remove the latch and then remove switch,it comes out by twisting,and then pull up,to install new one,line up slots push in and turn to lock in place,good luck.
May 03, 2010 | 2003 Chevrolet Avalanche
Alarm keeps going off after i lock car with security system on
most likely a door pin switch or trunk switch malfunction or switch adjustment.hope this helps
May 12, 2009 | 2007 Saturn ION-2 Quad Coupe
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Dynex 32 in. LCD Flat-Panel HDTV Logo
16 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
