Question about Acer aspire 5733z4851 intel pentium dualcore 4gb 500gb dvdrw 15.6 win
Hi. I have an acer aspire 5733z laptop which I has been working fine for the past 4 months or so. I went on the net this morning, everything was ok. Then went to go on a different site and the internet connection has dropped out and cannot get it back online! I have read on here to run devmgmt.msc and locate network adapters which I have done. There are 3 options - 1 has an exclamation mark next to it (Microsoft ISATAP Adapter #3). I click on this and device status is " This device cannot start (Code 10)". I have no idea how to start this! Can anyone help at all? Thanks.
  • Acer Master
  • 2,878 Answers
Download LAN driver, extract and copy to pen drive, then execute setup an ACER Aspire 5733.
http://support.acer.com/product/default.aspx?modelId=3680
Posted on Dec 06, 2012
  • 3 more comments
  • davewig1980
    davewig1980 Dec 07, 2012
    Hi and thanks for you response. I have downloaded from link you provided onto a USB stick. I have tried it on the laptop but no success unfortunately. There are 2 folders which have been downloaded which I unzipped before putting on stick. There were called ia32 and x64. Within these folders were a setup application. One didn't work at all. The other uninstalled something and then when reinstalling it, it says its was installed successfully but the internet is still not working. Any other suggestions what we can do?
  • Jose Diaz
    Jose Diaz Dec 07, 2012
    Post back with OS version, and if there are any other Network Adapter warnings in Device Manager. You can also check Network Connections in Control Panel for disabled LAN connections.
  • davewig1980
    OS is Windows 7 Home Premium Service Pack 1. There was a warning against a Network Adapter as mentioned in original post against Microsoft ISATAP Adapter #3. I can see that the LAN connection is disabled but the wireless network connection 2 is enabled.
  • Jose Diaz
    Enable the other LAN connection. It may come up with a red warning for not having a cable connected. Now try and test one port at time for internet. A reboot may help clear and renew, or you can also do an IP refresh. Go to Start > Search and type cmd. In the command prompt type ipconfig /release. Then type ipconfig /renew. This just refreshes your IP. Test the port one at time while doing these commands. Hit ENTER to execute commands. PS just noticed there is a Suggested Solution below. These are auto inserted by web site, even though one of then is mine. LOL
  • davewig1980
    I have disabled the wireless connection and enabled the LAN connection. I have then plugged in the ethernet cable and internet now works but only when ethernet is connected (obviously!). Does this suggest that there is a problem with the internal modem? Can this be fixed rather than having a cable trailing across the living room?! I haven't done the ipconfig prompts you mentioned yet though
3 Suggested Answers
jadiazq
  • 2878 Answers
SOURCE: i have an acer aspire 5742 ....the problem is when i turn my laptop on ..it shows acer logo during POST and then restarts again ....i tried pressing f2 to go to system settings but system settings do
Try System File Checker. It finds and replaces corrupted system files. You may need a copy of OS. At command prompt type sfc /scannow ENTER.
You can also use the Win 7 install disc:
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option. Type bootrec /fixboot ENTER if end up at the command prompt. It does the same thing.
Posted on Nov 27, 2012
Testimonial: "i tries your solution ...sadly it did not work ...but it was a possibility ...thanks "
  • 4961 Answers
SOURCE: acer e630 will not acknowledge boot disc and also keeps on telling me that i need to check cable connection, which i have done and all is in order
Time to bring it in to a computer shop to be fixed. It could be anything from your motherboard going bad, your DVD drive going bad, your hard drive dying, or even viruses and malware. Or a combination of the four.
Have them give you an estimate before they do any work on it as it may not be cost effective to fix.
Posted on May 15, 2012
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Webcam is not working
Hey Joseph,
If you DO HAVE an acer aspire 5733z, then here is a direct link to the web cam drivers from Acer
Copy from here -- >http://global-download.acer.com/GDFiles/Application/Camera/Camera_Cyberlink_1.0.1523_W7x86W7x64_A.zip?acerid=634406900772581500&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE 5733Z&OS=ALL&LC=en&BC=ACER&SC=PA_6<--To here
Don't click the link as it doesn't appear to have created the complete link when I pasted it in, instead copy and paste it.
Sep 26, 2013 | Acer 5733z-4851-Aspire 5733z-4851 Intel...
Acer manual
http://www.manualslib.com/products/Acer-Aspire-5733z-4851-2334114.html Here you go!
Aug 28, 2013 | Acer Aspire 5733z-4851
Can i make a acer aspire 5733z-4851 to be a touch screen
if the LCD is touch screen. absolutely cannot. anyway you can always touch the screen of your laptop. JOKE.
Dec 29, 2012 | Computers & Internet
Acer aspire 5733z does not detect dvd drive
This sounds like your dvd drive stopped working. try with different cds or dvds. If not there is a complicated way but if you are not familiar with computers don't do that. A service technician can easily solve it for you.
Dec 02, 2012 | Computers & Internet
My web cam and microphone is not working due to the absence of proper driver
Download the device drivers from the Acer WEB site. Make sure you select the model of your laptop the drivers you that require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Sep 02, 2012 | Acer 5733z-4851-Aspire 5733z-4851 Intel...
My skype used to work fine in my acer aspire 5742 but now it says there is a problem with a programme and it does not open skype anymore... everything else works fine. any solutions..????
You are probably experiencing another Skype outage. We are, too, this morning (6-7-2011). Click on Skype and it crashes. Reboot and it fails to connect. It's not your computer, it's Skype. I've read many other reports of the identical problem across the net.
Jun 07, 2011 | Acer Aspire 5742Z-4200 Notebook
Acer aspire 5733z4851 intel pentium dualcore 4gb 500gb dvdrw 15.6 win Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
