Question about Dell Computers & Internet
Dell insperion 530 screen is black with amber power light
Will not power up.Hear one beep.Screen is blank.
  • Dell Master
  • 7,733 Answers
Seems like you had a hardware issue.Try first to reset the memory sticks and the other is the HD.Is the HD is burn try a used one or buy a new one and reinstall the OS.
Posted on Dec 06, 2012
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
oblivion2k
  • 150 Answers
SOURCE: computer locking at startup
If the LED is glowing Amber then there is definitely something wrong with the hardware. Open up the system and check to make sure that all cables are plugged into the motherboard securely. If they are, you have faulty hardware somewhere. I would take it into a repair shop and see if they can locate the fault.
Please rate,
Thanks!
Posted on Apr 02, 2009
Universal T
  • 8 Answers
SOURCE: Solid Amber light when starting the Inspiron 530
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Posted on Jul 30, 2009
gpcomputer01
  • 137 Answers
SOURCE: My Dell Inspiron 530 wont turn on
yes buy a power supply. I have seen hundreds of computers that have gone through storms. Remember a Dell usually uses a special power supply.
For a good deal look on ebay for your specific model, They almost always have "Buy it Now" deals.
Posted on Aug 15, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
Aug 01, 2013 | Dell PowerEdge 1600SC Server
Dell insperion 5030 screen black and beeping
This POST code means there is a problem with the RAM.
Reseat the RAM and if the Dell still does not boot up then -
If it still does not boot up then could be faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 08, 2012 | Dell Computers & Internet
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
For example:
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Computer locking at startup
Please rate,
Thanks!
Apr 02, 2009 | Dell Inspiron 530 Desktop Computer
Black screen on start up
yep
unplug the system
open the case
wait ten minutes
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
79 people viewed this question
Alun Cox
