Question about Dometic NDR 1062 Refrigerator
Frdge freezing everything
I have a Dometic Gas/Ac refrdgerator in my camper. We had not used it for a couple of years, then when we did plug it in to AC it froze everything in it.
I was set on 2 on the setting on the outside front of it.
Is there something that may be clogged or plugged that would make it run continully, to make it freeze.
We had found muddauber nests in most of the other vents, I.E. furnace, water heater, etc.
Is there something we can check ?
    Sniper:
  • 68 Answers
Check to make sure the thermistor is attached to the fins on the inside of the fridge. Otherwise you may have a bad control cable assy.
Posted on Mar 19, 2009
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
2008 camper. fridge keeps switching over to gas. Turned it off & back on, it goes back to AC. The camper is plugged into a 50amp outlet & all else works fine.
Check your fuses and circuit breakers to see if any are tripped or blown. If you are handy with a test meter you can check for power at the refrigerator control panel. There will be a vented cover outside behind your fridge and there are two leads going to a heating element. You can check for power or continuity through the element.
May 12, 2015 | Dometic RM2852 Refrigerator
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
The frig is freezing everything down to the bottom drawers. Water, soda hamburger patties in the frig were frozen. It seems to be okay the first day and then it turns into a freezer. Any idea what I should...
Dometic refrigerators don't have the best thermostats, especially the one with multiple source (AC/DC/Propane) . They are also prone to be more sensitive when the propane was just topped up and the pressure is high.
Don't get me wrong, I think the Dometic is a great refrigerator for campers, you just have to learn to deal with its issues.
Also make sure that you have one fuel source selected at a time, and not all of them!
Jun 30, 2011 | Dometic Refrigerators
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Inop on ac electric
There should be fuses/breakers in the converter box. It sounds like the DC circuit is ok but the AC portion is still out. Eric
Jun 20, 2009 | Dometic Refrigerators
Unit will not turn onto AC
Heating element is burned out
Oct 20, 2008 | Dometic NDR 1292 Refrigerator
Dometic NDR 1062 Refrigerator Logo
181 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
