Hi, got a prolem with our oil fired boiler. To
Hi, got a prolem with our oil fired boiler. To start with it wasn't firing at all so I replaced the room thermostat with an RTS1, the boiler worked perfectly for 2 days then began to go wrong, not firing when the thermostat was requesting heat. I then replaced the old drayton programmer with a new Drayton Lifestyle LP522. Again, it worked perfectly for about 2 days and then the same problem occurred, boiler not firing etc. Is my boiler possessed or something? Going off my head. Help :-(
Da Brain
  • 11 Answers
SOURCE: Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Posted on Oct 27, 2008
  • 44 Answers
SOURCE: I've a problem with my
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Posted on Dec 15, 2008
machtcl1
  • 61 Answers
SOURCE: Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Posted on Jan 10, 2009
SOURCE: my boiler keeps firing up
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
Posted on Apr 23, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Honeywell troubleshoot
Is the temp in the room higher then the tstat setting? If so the unit will not come on. Try setting it up to maximum, it should then come on within a few minutes.
Aug 18, 2014 | Heating & Cooling
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
I do not have a room thermostat connected to my oil fired central heating boiler. I want to install a wireless room thermostat to avoid having to run cable. how do i go about this and which is the best...
All wireless wall thermostats are Millivolt controlled. rather than having an 18 or 24 volt (transformer) wired wall thermostat. Before purchasing any wireless wall thermostat, you need to determine what your oil fired boiler requires for activation. My experience tells me, that it's going to require either 18 or 24 volts. In which case a wireless thermostat won't work.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
I have a Weil-McLain hot water boiler for baseboard heat. The system has one circulator pump. The system has 5 zones - 3 work fine and two are not working. All the zone valves and thermostats are...
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
Sep 20, 2010 | Honeywell (CT62B1015) Baseboard Heater
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
