Question about LG LFX25960ST Stainless Steel French Door Refrigerator
MY LG fridge model# LFX25960TT interior lights will not go on...there new
LG fridge modelLFX25960TT interior lights will not go on. I was placing items in side the fridge when i notice that the lights were off. i got new ones and still does not work. i get no error signs. could it have a blown fuse in the back of the fridge ?
    Top Expert:
  • LG Master
  • 9,472 Answers
Check the door switch to see if it is working. Here is the switch to order in case you find it bad.
Posted on Dec 05, 2012
Noggin
  • 944 Answers
SOURCE: outer back and side of fridge is very hot
Turn it off. If you keep running it, it will die completely fairly soon. Please feel free to jump to the end if you don't want a fridge science lecture - it might help you figure out the problem though. When a fridge/freezer runs, the condenser (all the tubes at the back) will get warm-hot. That is where the heat goes from inside the fridge. First thing to check; is there excessive heat to remove from the fridge/freezer? Check the door seals are ok - cold air falling out of a bad door seal can make a fridge both cool and warm a room at the same time - which obviously leads to problems Check that the lights inside actually go off when you close the door by pressing the switch that the door usually presses when it shuts, and checking that the door will press the switch as far as it needs to go. Second thing; Check that there is adequate ventilation at the back - remember the ideal situation technically for a fridge is to have the bit at the back outside the house in the shade like an air-con unit. pull the fridge a bit more away from the wall and try blowing a fan onto it. Clean gently with a soft brush any dust etc that is on all the tubes at the back - it can cause an insulating coat to form. If the dust is sticky and hard to shift, then gently use a soft paintbrush and warm soapy water. Third thing; When the amount of refrigerant gas in a fridge system is getting low (they all leak a tiny bit all the time - even without any fault) two main things happen: The fridge gas has a lubricant mixed in with it that keeps the inside parts of the system oiled. when the gas is low, so is the oil and you get the same effect as running a car with no oil - runs hot, then dies. The low gas has an effect inside and outside the fridge - inside, near where the gas first enters the evaporator (the plate in the fridge that gets cold) it will get extra cold. the compressed refrigerant evaporates too quickly - easy way to explain is that there is nothing in front of it in the queue so it runs through too quick. the same thing happens in reverse when the gas goes into the condenser at the back, the gas condenses too quickly making the back very hot. I think, from what you say, that low gas is the problem. Although it is not too complicated, it is illegal for you to do it yourself in most places for environmental and safety reasons - get any fridge repair guy and he can do it and check for leaks at the same time. Hope this helps, and is in time to save your fridge :)
Posted on Mar 28, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Posted on Feb 09, 2009
  • 10 Answers
SOURCE: Interior light bulbs stay on?
There is a switch on the inside of your frige that has gone bad. The switch is a slide type switch so when you open or close the door it makes the switch slide in and out, making the light come on and off. You need to write down the make and model # of your refrigerator and order a new switch either from the manufacturer or from the place you bought it. Once you have the new switch, unplug the refrigerator, take a flat head screw driver and gently pry the switch from the interior face, pull the two wires off and replace the old switch with the new. The switch is very inexpensive and very easy to replace. Calling a service technician out to do this could cost you more than you expect. If you are not very "mechanicaly enclinded" then just order the switch and have a brother, neihbor, or someone that is mechanicaly savy come over and fix it for you. It should not even take 5 minutes. ;-)
Posted on Aug 11, 2009
SOURCE: LG LFC23760ST Side by Side Bottom - Slow Blow or fast blow fuse?
slow
Posted on Aug 13, 2010
MNTECH
  • 1543 Answers
SOURCE: Model LFX25960TT is showing an error code of Er
The control board is not seeing a feedback signal indicating that the freezer fan is running. Check for a build up of frost in the freezer compartment which may be preventing the fan blade from turning.
Posted on Feb 26, 2011
I have a LG fridge freezer that wont stop beeping any help would be greatful model number..GWB227WLQA
Most new style have a warning tone that door is open.
start by manually pushing any door switches ( interior lights should go out). If light stays on you have faulty switch.
Freezer with no light a little harder, but if you have meter and are able to get switch out you can test for continuity.
Not sure of voltage to switch so remove power to fridge while removing switch.
With power removed ( unplugged) you maybe able to remove switch and connect wires together with electrical tape. Plug unit back in see if alarm is off.
Remember if not comfortable with that process call service.
Sep 22, 2016 | LG Refrigerators
LG LSC26905TT refrigerator not freezing. Everything is melting in the freezer and fridge.. Lights are on, but no cold air is coming.
Remove all items from the fridge and keep open the fridge doors for atleast 2 days and that will remove all the frosted ice on the evaporator(which can't be seen) and shall work fine after two days.
Feb 26, 2014 | LG LSC26905TT Side by Side Refrigerator
LG Refrigerator side by side suddenly not working at all other than interior lights.
If you're lucky, it's just the capacitor on the motor. Have it checked, but be prepared to need a new compressor.
Mar 10, 2012 | Refrigerators
The light has not been turning off which melted the plastic covering over the light bulbs and its not hanging by a wire and the light still on. the censers on the door do not turn it off anymore i...
Karri,
I experienced the same problem with my LG refrigerator (model LFC25760ST). Came home from a weekend trip only to find that the light bulb assembly had melted and dropped onto the top shelf. The interior of the refirgerator compartment was very warm (est. 70 to 80 degrees) and everything in it had spoiled. Fortunately, nothing worse had happened. (According to consumer information on the Internet this LG refrigerator is suspected - but not proven - to have been the cause of a couple of house fires.)
There was no recall, however, because the reports to the Consumer Products Safety Commission were for less than 5% of this model sold in the U.S. But if you contact LG customer service (1-800-243-0000) whether your unit is still under warranty or not they should send someone out to replace the lamp assembly at no charge to you - this one with a heat sensor that serves as a backup to turning the lights off once the doors are closed.
Newer LG refrigerators have LED lights instead of incandescent light bulbs so they don't produce enough heat to warm the interior of the fridge or melt the light housing.
To learn more about other folk's similar experiences with these LG refrigerators just do an Internet search using "LG and "LCF25760" and "melted plastic." (Note: Leave the other letters after the five numbers in the model number off - they only refer to the exterior finish [i.e., "ST" = stainless steel] and unnecessarily narrow the search so as to miss some links.
Good luck with LG customer service.
grm
Feb 15, 2011 | LG LRFD25850 French Door Refrigerator
We have a 4 year old LG fridge obviously out of warrenty. Repair man was just here. Why does LG wire lights into main board? Why does LG install TWO 60 watt bulbs (120 watts!!) when the notice in the...
LG issued a service flash about this very problem, so you may be in luck. The last one I did for a customer was paid for by LG.. In a nutshell, LG screwed up. The control board that the lights tie into has a bad relay, which causes the lights to stay on all the time. The fix is to get a new control board and a new light harness. The new harness has a thermal switch that shuts off the lights should they not shut off in the future. I'd try LG customer service and see if they can help you out.
Good Luck!
Sep 29, 2010 | LG Refrigerators
Lg premium ez digital i have a lg premium ez digital fridge freezer the interior light bulb has expired. how do i replace it please.
Unscrew it from the socket. counter clockwise. remove it entirely. screw in new bulb, clockwise
Sep 29, 2010 | Freezers
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Aug 10, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
423 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
