Question about NetGear Computers & Internet
Need password My netgear extender is supposed to use the router password but won' t recognise it
  • NetGear Master
  • 7,733 Answers
Try to reset the router see http://www.fixya.com/support/r11153882-general_routers_reseting
Posted on Dec 06, 2012
2 Suggested Answers
  • 382 Answers
SOURCE: My Dell C510 sees my netgear wifi but will not let
Are you the one who configure the router before?, If yes better to reset your router then reconfigure it again. Just a thought hope it helps thanks.
Posted on Sep 23, 2011
Got a Netgear wifi extender but my current password won't work to access the new_ext network.......don't know what to do!
You need a new password to access the new wi-fi extender, you cannot use the existing router password.
Oct 20, 2013 | NetGear Universal WiFi Range Extender...
Setup wizard
the password should be the same password of your wifi on the router...
Aug 21, 2013 | NetGear WN2000RPT Repeater
401 authorization required
It does not recognise the password.
Check this and the protocol used to access the wireless extender.
Jun 03, 2013 | NetGear WPN824EXT RangeMax WiFi Range...
Cannot connect NetGear WN3000RP with wireless
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference TechSpot.com for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router Passwords.com for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
b>
Dec 05, 2012 | NetGear Universal WiFi Range Extender...
I have to change my router from wpa to wep and can't figure out how to do it. I have printed out instructions and it tells me to go here or there but when I do the options I'm supposed to cl
All you need to do is , open the setup page of the router and change the wireless security settings.
Go to Wireless section.
Select WEP.
In the key 1 box type 10 digit hexadecimal number.
This 10 digit number will be the password of your network.
Jun 14, 2012 | NetGear Computers & Internet
I need to know what my WEP key or WPA passphrase are
You cannot view it, you can only erase it and create a new one. To do this, grab a pen or pencil and hold it down on the small button on your router in the back. This will cause your router to reset all settings, re-naming your wireless network back to NETGEAR with no password. Plug a network cable from your computer to the router, go to your browser and type in "192.168.1.1" and it will ask for a username and password. The username is 'admin' and the password is 'password'. Find the setting for configuring a new wireless password and you should be good to go! Let me know if this helped by leaving me a positive rating!
Jul 07, 2011 | NetGear WGR614 Wireless Router
I have just purchased an iPad 2 and it's asking me for my Netgear password; the default password doesn't work, so I must have changed it - but I can't remember what I changed it to!
so then you can simply reset the router so to go back to its default password ...or if you want to know your recent password, simply use your computer that is currently connected to your router and is working...then follow the steps in this link http://netspace.custhelp.com/cgi-bin/netspace.cfg/php/enduser/std_adp.php?p_faqid=508&p_created=1216184248 Configuring your Netgear DG834G & DG834GV Wireless Network
Note: you dont need to configure the wireless just check the password you have setup there so you can connect your ipad wirelessly...
Thats it!! (-_-)
Jul 05, 2011 | NetGear DG834G Router
D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Feb 01, 2010 | D-Link DIR-615 Wireless Router
My msi u100 mini laptop recognised my wireless router but is not letting me connect i have inputed my network key off the side of my net gear router ,it won t accept it
Do you mean the encryption key? It may have been changed.
If so you can reset the Netgear back to the default settings and setup a new encryption key.
To RESET the router, press the pinhole RESET button at the back of the router for approx. 10 secs until the LEDs flash.
For instrustions on how to secure and configure the Netgear wireless router and the wireless card in the computer/laptop please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
The Netgear configuration URL http://192.168.0.1
Default login = admin
Default PW = password
Should you need further help, please leave me a comment.
Dec 25, 2009 | MSI Wind U100-030US Laptop
Netgear router WGR614
try using "admin" for the user and "password" for the password. I have this very same router and that was the default settings for me.
Nov 19, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
60 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
